STL to SOLID -> Scale and Subtract
I've been trying to accomplish this for month and almost tried every program there is in 3D world, I kid you not!
So I want to create a solid from an stl => Succes after weeks I found that FreeCAD Is the program whereas I succeeded to convert STL to a SOLID.
Now, want baffles me is that I can't scale that solid or copy paste in place it. I want to hollow out my shape but have an overall 2-3 mm shell.
So I can 3D print it and put things in it!
Also later I want to add a screw hole and removable lid. (but first things first)
How do I achieve this in FreeCAD. I've read the scaling with draft clone but that didn't work for me or I just don't get it probably.
Files are in the attachments
OS: Windows 8.1 => BOOTCAMP ON A MAC
Word size of FreeCAD: 32-bit
Version: 0.16.6700 (Git)
Branch: releases/FreeCAD-0-16
Hash: 7b925d11aa69ac405b423635adb1e2833f18a817
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
I hope I get an answer on this forum, because solidworks and vectorworks are pretty much dead.
Qt version: 4.8.6
- dodecahedron.FCStd
- Freecad Solid
- (22.67 KiB) Downloaded 65 times
- V001Dodecahedron.stl
- absolute original
- (10.61 KiB) Downloaded 123 times
- V001Dodecahedron - OpenSCAD_Model (repaired).stl
- The original stl repaired in solid works
- (2.82 KiB) Downloaded 112 times
Re: STL to SOLID -> Scale and Subtract
Hi BLCKPSTV, and welcome!
Word size of OS: 32-bit
Version: 0.16.6698 (Git)
Build type: None
Hash: ca7c5d31a4d61f32a25b71025b14641a6e378328
Python version: 2.7.6
Qt version: 4.8.6
blue = edit
See below:BLCKPSTV wrote:How do I achieve this in FreeCAD.
I imported your absolute original dodecahedron .stl into FreeCAD, then used Part WB > Part pull-down menu > Create shape from mesh, and that worked OK.BLCKPSTV wrote:So I want to create a solid from an stl => Succes after weeks I found that FreeCAD Is the program whereas I succeeded to convert STL to a SOLID.
Select the solid in the hierarchy tree, then use Draft WB > Clone. Select the Clone in the hierarchy tree, and change the Scale properties in the Data tab.BLCKPSTV wrote:Now, want baffles me is that I can't scale that solid
Hmm... Ctrl + C and then Ctrl + V works for me.BLCKPSTV wrote:or copy paste in place it.
To hollow out your model, select the face where the lid will be and use the Part WB > Thickness tool. The selected face will be removed. I see why you want to Scale the solid - as imported the .stl is only 3.28 mm tall... OS: Ubuntu 14.04.4 LTSBLCKPSTV wrote:I want to hollow out my shape but have an overall 2-3 mm shell.
Build type: None
Qt version: 4.8.6
blue = edit
Why the heck would you run the Windows version of FreeCAD in Bootcamp when there's already a Mac build?BLCKPSTV wrote:OS: Windows 8.1 => BOOTCAMP ON A MAC
I've been trying to grasp this and try and try without sounding like somebody who didn't do his homework and still complains.
But I don't get the hollowing part explanation.
So I want the solid empty on the inside (I want it solid but still empty ) But no serious I want the solid piece to be empty on the inside and the solid should be 3mm thick. I need to put extra holes in it afterwards.
But still I did this and I said select one or more faces of a shape whilst I selected them all and specific ones.
I don't know how to ask it otherwise, I clearly lack the correct terminology in Freecad
I didn't get this, because I don't want a lid.To hollow out your model, select the face where the lid will be and use the Part WB > Thickness tool. The selected face will be removed. I see why you want to Scale the solid - as imported the .stl is only 3.28 mm tall...
Part:Create shape from mesh
Part:Make solid
Centred the solid on origin with Workfeature plugin centre of mass point an use Draft move to centre by this reference.
Scaled a copy with reference origin by 0.9
part cup small from big.
Cut with a cube so you can look inside
Part:Make solid
- test31.fcstd
- (136.33 KiB) Downloaded 36 times
Omg that's it!!Part:Create shape from mesh
Part:Make solid
I'm going to try to remake it like you did and see what I did different!!
(UPDATE)
I've got the Workfeature installed.
ßut now I don't get how that works...
I first went a step back and tried to scale the part to the size I want (being 120mm Z axis and the other axis relative to the Z axis) but that doesn't work.
I did select solid > draft > scale > Task View I see Global X, Global Y and Global Z (what do I do here?) and Enter Point? + continue and copy > Close
Pff it so hard learning a new drawing software -.-
Add a body and a plane in 0.17 development version and you can realy go to town
Do not know exactly you mean by a lid?
Dude how do you do that so easily! :'(
You're doing quasi exactly what I want, but I'm not able to achieve this!!
I've updated my former reply, with what I did!
Love it that I found somebody that understood my gibberish of what I wanted to create!
I'm not giving up now with Freecad!!
On workfeature there is a point tab with Object center.
select the part and click the object center. If you hide the part after you can see the point.
Using the Draft workbench:Move command. to do this do the following.
Make sure you are on XZ work plane
Select the part
Hide the part
click the move tool
select the center point
Make shure grid snap is on, and select orign.
Make part visible again.
Part has now been centered on orign in xy axis
Do the same for XZ axis
Now its centered completely.
Use the Scale tool with reference on origin using snap grid.
If you get here I will continue. Have to go now Good luck
Select the part
Hide the part
click the move tool
I uploaded the file so you see what's wrong?! I'm also still taking a hang on the navigation styles. Now using the CAD way.cox wrote:On workfeature there is a point tab with Object center.
=> You mean XY ?? see origin lower.
Select the part
Hide the part
click the move tool
=> Mine version on mac crashed a few time on this. And I'm guessing the origin is the black line?
=> I think I got it to work but something is still wrong, I think it's the centering part I did something wrong at.
And do I have to do it for the 3 axis or only 2?
=> So I'm not there yet, but bare with me later on tonight I trying it again!!
- V001Dodecahedron3.FCStd
- third try
- (22.12 KiB) Downloaded 35 times
- V001Dodecahedron2.FCStd
- second try
- (20.32 KiB) Downloaded 33 times
- V001Dodecahedron.FCStd
- first try
- (38.15 KiB) Downloaded 41 times
