PartDesign Next - additive box to center
triplus
Re: PartDesign Next - additive box to center
Post by triplus »
DeepSOIC wrote:to center of volume
I guess general option to use this as a reference in operations would be nice.
renatorivo
Post by renatorivo »
renatorivo wrote:I seem to have solved with Draft->Clone:
then select the clone and create a new body to continue modeling,
DeepSOIC
Post by DeepSOIC »
What do you think?
Renato
I think you better off solving the problem with Part Box primitive. At least, I fail to see the benefit of using PartDesign Box -> Draft Clone vs. Part Box.
renatorivo
DeepSOIC wrote:I think you better off solving the problem with Part Box primitive. At least, I fail to see the benefit of using PartDesign Box -> Draft Clone vs. Part Box.
True, Part-> Box does not create cyclic dependencies, and the workflow is simpler.
Thanks,
Renato
hmk
Post by hmk »
Reviving an old thread after some years:
I managed to center a Additive box by attaching a Datum point (placed at the origin) to the box with Translate origin as the attachment mode. I hope the screenshot is sufficiently descriptive.
I was wondering, any thoughts/comment if this is a good strategy?
Screenshot from 2021-01-06 16-48-27.png (56.51 KiB) Viewed 746 times
Bance
Post by Bance »
Start a new thread.
The DatumPoint seems useless here, if you use expressions for the placement anyway.
hmk
Post by hmk »
Bance wrote: Wed Jan 06, 2021 5:58 pm Start a new thread.
I thought it's a natural continuation...
hmk
Post by hmk »
chrisb wrote: Wed Jan 06, 2021 11:20 pm The DatumPoint seems useless here, if you use expressions for the placement anyway.
Thanks a lot for your feedback.
Without the DatumPoint I did not have the Placement property to work with. The Additive box itself does not have it!?
Bance
Post by Bance »
The software has changed to the point that it no longer resembles that of 5years ago!
After you have attached the Box offset is available:-
Snip macro screenshot-ad7308.png (45.1 KiB) Viewed 665 times
