OS: Windows 7
Version: 0.17.7709 (Git)
Hash: 7f2833b465f544a8d49a36382c00e7c9c85a4abb
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
I have been struggling in Part Design with making a simple polar array of holes around an axis other than one of the basic body axes.
I have already independently created the object by using Part and Draft Workbenches, so this is more for curiosity and perhaps bug reporting.
For this example I used the following steps, completely in Part Design Workbench
1. Start with new document in FC17.
2. Create body.
3. Create basic block through the normal sketch and pad procedures.
4. Create helper pad by creating sketch on top face of basic block and padding.
5. Create prototype hole by creating sketch on top face of block and pocketing.
6. Create polar pattern.
-- Set the number of holes.
-- Choose "Select reference..." in the axis drop-down menu item and click on a vertical edge of the helper pad.
-- No error messages, but the axis does not change.
-- Log trace shows the correct axis is selected, but when the "OK" is clicked to finish the polar task the axis reverts back to (0,0,0).
7. I added the extra "visualization" pad at the end only to show where I want the circle of holes.
I am using the Gesture style of navigation, but I tried other styles with no change in the polar behavior.
As a side note which may or may not be related, Graphviz crashes about the time the polar array is attempted. (Graphviz crashes frequently when I use FC17.)
Gene
Polar array axis selection
Re: Polar array axis selection
Hello.
I haven't had time to explore 0.17 yet, but i think according to here (point 4.) you maybe need a datum line as axis ?
Roland
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
- DeepSOIC
Yep, doesn't work. Please create a ticket in tracker.
EDIT: doesn't work with datum lines either.
Thanks for looking and for the input. I have submitted bug report issue #2582 describing this behavior.
http://www.freecadweb.org/tracker/view.php?id=2582
Gene
Gene
Reason: made bug link
