Nurbs editor
Re: Nurbs editor
This is a great news! What we can do for help you?
Re: Nurbs editor
This is a link collection of NURBS editor, I Hope can help you https://www.blender.org/forum/viewtopic.php?t=18026
- microelly2
Re: Nurbs editor
Some new generic surface types with random test data
examples here:
http://freecadbuch.de/doku.php?id=blog: ... _und_torus
examples here:
- bp_198.png (17.4 KiB) Viewed 2929 times
Re: Nurbs editor
Hi Microelly2, I have installed the Nurbs Editor plugin, but I wasen't able to use.
I have found a video where an important design Company uses the same workflow that i want create, but i want use only Blender and Freecad.
This is the Video: https://www.youtube.com/watch?v=vAONd8DydxA
I have find also how is possible import the obj/stl file from Blender to Alias for create a Nurbs surface and export file iges/step: https://www.youtube.com/watch?v=bzgIV3q ... 1LSzptm7C2
There is also a pluging for Moi3d that transform the polygon file in Nurbs, but it is not parametric and it works only with quad mesh: https://www.youtube.com/watch?v=8BhtWMy6A-4
I hope this information can help
- microelly2
Re: Nurbs editor
To help you I need a description what fails.gara01 wrote:Hi Microelly2, I have installed the Nurbs Editor plugin, but I wasen't able to use.
There is a method to import nurbs from Blender to FreeCAD.
The main task will be to reduce triangle meshes to quad meshes. There is a lot of theory but still no running script.
transform quad meshes to nurbs subfaces is not a problem.
the import of quad mesh structures is done in the geodat workbench
viewtopic.php?f=8&t=6973&start=110#p135536
viewtopic.php?f=3&t=18445
the main task is to split the surface into superquads that can be mappend 1:1 to nurbs.
what I want sometime in the future is to postprocess the objects of makehuman: http://www.makehuman.org/
yes, thank you for these links. good to know the direction where to go.
No time for boredom.
Re: Nurbs editor
That is what I'm searching
How can I do transform the polygon quad mesh in nurbs?
- microelly2
Re: Nurbs editor
If you have a quad mesh detail in form of a 2d vector array pts=[[v1,v2,vn],[v21,v21,v2n], ...[..]]gara01 wrote: How can I do transform the polygon quad mesh in nurbs?
you perform a
bs=Part.BSplineSurface()
bs.interpolate(pts)
and then you get the poles
bs.getPoles()
and you can start postprocessing
Re: Nurbs editor
Sorry for my ignorance. I have created a Cube with Blender and export it in Obj format, but when i import the Cube, Freecad transform the Cube in triangle mesh. What am I doing wrong?
Re: Nurbs editor
Probably nothing because the mesh is always made of triangles, so any flat rectangular face will always be composed of two triangular faces.gara01 wrote:What am I doing wrong?
I think you posted your question in the wrong topic though...
