Hi all freecad lovers ..at the moment i struggle with the draft dimension tool. In the description is the information about a dynamic dimension.
But if i try this option all what i get is the result in the following picture only the angle seams to work.
Non dynamic dimension seams to work.
I use the pre releas version FreeCAD_0.17.7801_x64_dev_win ...maybe someone can confirm the behaviour or better can explaining me what i am doing wrong and how i should use it as i understand is this dimension tool with ALT dynamic.
Big thanks in advanced for help.
Draft dimension question
Re: Draft dimension question
Looks like a bug to me.
0.16.6703 Release works as expected, in 0.17.7833 applying the Draft dimension with the [Alt] modifier results in a 1 mm dimension and it is not parametric.
Mark
OS: Kubuntu 14.04.4 LTS
Version: 0.17.7833 (Git)
Hash: d9b7a5fbbf7c444c7ab94473a11449840a946313
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Mark
Qt version: 4.8.6
Thanks for response i will report it to the bugtracker
