Testing TechDraw
Mongrel_Shark
Re: Testing TechDraw
Post by Mongrel_Shark »
yorik wrote: Sat Aug 19, 2017 2:32 pm
Both Drawing and TechDraw use the same system to make texts editable:
https://www.freecadweb.org/wiki/Drawing_Template_HowTo
Thats odd. Then why does the template I made with that guide not have any editable text? It works in drawing or drawing dimensioning, but not in tech draw.
Could it be that the text is a small size and the green dot is not visable?
I can't post the full file as the boss could get upset, but I can provide a few screen shots of the code I changed in the svg. Took me a whole weekend and 8 revisions to get it working last time. Has about 40 editable fields...
Here is the top of the .svg text
.Plan Template fre8.svg (~-CAD-Ozone1) - gedit_070.png (195.93 KiB) Viewed 2075 times
and a couple of freecad editable bits.
.Plan Template fre8.svg (~-CAD-Ozone1) - gedit_067.png (188.35 KiB) Viewed 2075 times
.Plan Template fre8.svg (~-CAD-Ozone1) - gedit_068.png (191.76 KiB) Viewed 2075 times
And the end of the document.
.Plan Template fre8.svg (~-CAD-Ozone1) - gedit_069.png (188.18 KiB) Viewed 2075 times
It works in drawing but not in tech draw....
Hopefully I did something obvious and someone can help me fix it. :?:
Mongrel_Shark
I just realised there are dedicated Tech draw templates and the editable text parts are very very different.
Its all at the very bottom of the text file, and based on location coordinates. So much easier to deal with. Yay!!
I'm going to have a crack at my template, Will probably break stuff. Help would be awesome. (Help with the template that is. I got the breaking stuff part well covered)
A3_Landscape_ISO7200TD.svg (-usr-share-freecad-daily-Mod-TechDraw-Templates) - gedit_071.png
A3_Landscape_ISO7200TD.svg (-usr-share-freecad-daily-Mod-TechDraw-Templates) - gedit_071.png (241.02 KiB) Viewed 2073 times
thschrader
Post by thschrader »
Mongrel_Shark wrote: Sat Aug 19, 2017 10:21 pm I just realised there are dedicated Tech draw templates...
As yorik said: you can use inkscape to edit the templates.
regards thomas
A3_Landscape_shark.svg
(78.44 KiB) Downloaded 235 times
shark_engineering.FCStd
(71.23 KiB) Downloaded 70 times
wandererfan
Post by wandererfan »
very simple template with EditableTexts attached.
A4_Landscape_EditableSample.svg
(2.41 KiB) Downloaded 196 times
Mongrel_Shark
Thanks for the help guys.
Seems the part I was missing is a new define required for Tech Draw.
<g id="FCText"> needs to be in the file somewhere above the freecad editable stuff.
Like this (I think)
</g>
<g id="FCText">
<path
inkscape:connector-curvature="0"
id="path3204"
style="fill:#ffffff;fill-opacity:1;fill-rule:evenodd;stroke:none"
d="m 1171.0317,322.55859 7.4567,0 0,9.01901 -7.4567,0 0,-9.01901 z" /><path
id="path3206"
style="fill:none;stroke:#000000;stroke-width:0.2174685;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:10;stroke-opacity:1;stroke-dasharray:none"
d="m 1171.0317,322.55859 7.4567,0 0,9.01901 -7.4567,0 0,-9.01901 z" /><g
transform="matrix(0.30460952,0,0,0.30184094,935.7755,-9.2877446)"
id="g3208"><text
id="text3210"
transform="matrix(0,0.9999,1,0,787.32,1108.29)"
freecad:editable="1.0"><tspan
id="tspan3212"
sodipodi:role="line"
y="0"
x="0 4.8020372 7.1980319"
style="font-size:9.60000038px;font-variant:normal;font-weight:normal;writing-mode:lr-tb;fill:#000000;fill-opacity:1;fill-rule:nonzero;stroke:none;font-family:TT19At00;-inkscape-font-specification:TT19At00">1.0</tspan></text>
My document is still really messed up.
I think too many transitions between text editor, inkscape and freecad has really messed up the X-Y data
For eg
<text
freecad:editable="5"
xml:space="preserve"
style="font-size:2.39726758px;font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;text-align:start;line-height:125%;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;fill:#000000;fill-opacity:1;stroke:none;font-family:Sans;-inkscape-font-specification:Sans"
x="215.1348"
y="1156.6674"
id="text14575"
sodipodi:linespacing="125%"
transform="matrix(0,1.0006203,0.99938008,0,0,0)"><tspan
id="tspan14577"
x="215.1348"
y="1156.6674">5</tspan></text>
<text
freecad:editable="56"
x="215.1348"
y="1152.5615"
id="text14579"
id="tspan14581"
x="215.1348"
y="1152.5615">56</tspan></text>
<text
style="font-size:2.39726734px;font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;text-align:start;line-height:125%;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;fill:#000000;fill-opacity:1;stroke:none;font-family:Sans;-inkscape-font-specification:Sans"
x="232.89124"
y="1168.7782"
id="text14591"
id="tspan14690"
x="232.89124"
y="1168.7782">Scale </tspan></text>
Looks at first like the decimal on the Y lines is one spot to the right of where it should be, but changing that doesn't put the fields in the right place. I think I have broken the document beyond repair and need to start from scratch. :cry:
Here is another section...
<text
transform="matrix(0,0.9954039,1.0046173,0,0,0)"
id="text3140"
x="291.77136"
y="1146.9475"
style="font-size:3.63851404px"
freecad:editable="Client name"><tspan
style="font-size:3.49297333px;font-variant:normal;font-weight:normal;writing-mode:lr-tb;fill:#000000;fill-opacity:1;fill-rule:nonzero;stroke:none;font-family:TT19At00;-inkscape-font-specification:TT19At00"
x="291.77136 293.556 295.15546 296.97623 298.8313 299.59521 301.41602 303.23416 305.08878 305.88763 306.65152 309.0163 309.81659 311.41602 313.20041"
y="1146.9475"
id="tspan3142">Client name</tspan></text>
On the bright side I worked out how to make a template another way. With almost no text editing of the .svg. Will make a new thread on that soon.
wandererfan
TechDraw Templates don't understand transforms for editable text yet. You need to use the absolute coordinates for X,Y location.
Transform for lines/graphics/uneditable text is fine.
