[bug#2682] -constraints with external geometry disapear after closing/opening the sketch
nemesis
Post by nemesis »
I don't know if it's a bug or a non yet implemented feature, so just in case as I found nothing about this in the forum.
OS: Windows 7
Version: 0.17.8291 (Git)
Hash: 94f07c85ee99c9cc94e144245fb97bedd0a38771
Python version: 2.7.8
OCC version: 7.0.0
1st step : use external datum plane in sketch constraints
2nd step make a pad :
3rd step change datum plane orientation to check the link with the sketch (70 to 75°) it works like a charm:
Back in the sketch, all external reference have disapear :
link is lost with the datum plane (back to 70°):
nemesis
Re: [bug?] -constraints with external geometry disapear after closing/opening the sketch
Post by nemesis »
and the test file
test (2).FCStd
(14.77 KiB) Downloaded 68 times
NormandC
Post by NormandC »
nemesis, the "Part Design module development" forum specifically dictates:
Your topic is not about development, it's about bug reporting, this should have been posted in the "Help on using FreeCAD" forum.
Please have a look at the "Bug submission guidelines" pinned at the top of the "Help on using FreeCAD" forum.
[quote="The "Bug submission guidelines" forum"]If you are unsure, discuss the problem on the forum first. Open a new topic here on the forum, in the help section, and ask if what you found is a bug. Other users will surely be able to help you determining what you should do.[/quote]
r-frank
Post by r-frank »
Moved topic to "Help on using FreeCAD"-forum ...
My GrabCAD FreeCAD-Projects
nemesis
Post by nemesis »
ok,
I thought that debugging a software was part of the devloppment... as I didn't ask for help
DeepSOIC
Post by DeepSOIC »
nemesis wrote:and the test file
I have opened your file, edited sketch -> there are no constraints. None. Zip. Just lines, nothing else.
But I seem to be able to confirm your bug - the links to datum planes seem to go away after closing->reopening a sketch.
DeepSOIC
Post by DeepSOIC »
Trying to debug. External geometry links are lost right while opening the sketch. And it is special to datum planes - links to another sketch survive just fine...
nemesis
Post by nemesis »
DeepSOIC wrote:I have opened your file, edited sketch -> there are no constraints. None. Zip. Just lines, nothing else.
Yep it looks like they disappear when saving the file.
while opening the file on OS X I also loose all the constraint. only the ones with external geometry where loosed on windows, without closing the file, so I have to check tomorrow on windows.
Deepsoic wrote:it is special to datum planes - links to another sketch survive just fine...
good to know, I guess that's easier to find the bug then.... or maybe not.
Bug report here
nemesis
Re: [bug] -constraints with external geometry disapear after closing/opening the sketch
Post by nemesis »
Also confirmed on OS X version:
OS: Mac OS X
Version: 0.17.8293 (Git)
Branch: (detached from 51e23d8)
Hash: 51e23d854e59ab0a23a9ea9b19e74e5f02753d82
Python version: 2.7.12
Coin version: 3.1.3
OCC version: 7.0.0
Post by Kunda1 »
@nemesis does this bug still exist ?
