[Solved] Draft/PathArray--Expected Behavior?
I am currently working on a model of a roller chain and discovered unusual or unexpected behavior when using the PathArray tool. The following is a simple example of a circular interlinking chain to illustrate the problem:
I searched the forum and user documentation but did not find much about PathArrays.
Is this the expected behavior or have I misapplied the PathArray?
The workaround is to simply rotate the base object 90 deg before applying the PathArray. This gets to be a bit confusing when attempting something a little more complicated like a roller chain.
This model was created in the XZ plane to avoid the aforementioned PathArray behavior: OS: Windows 8
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
The orientation of the links in the PathArray apparently depends on which plane the sketches are created. Note that the base objects (red links) are rotated 90 deg if constructed in the XY plane or the YZ plane. The links are NOT rotated if constructed in the XZ plane:I searched the forum and user documentation but did not find much about PathArrays.
- circular_chain.FCStd
- (47.66 KiB) Downloaded 139 times
"It is a poor workman who blames his tools..."
- wandererfan
Re: Draft/PathArray--Expected Behavior?
It's a bug, or at least missing functionality. PathArray doesn't know that changing the Placement of a Sketch based object doesn't move it. You need to change the Placement of the Sketch.ppemawm wrote:Is this the expected behavior or have I misapplied the PathArray?
I'll try to look deeper tomorrow.
wf.
I agree that behavior in X-Z plane is not logical. There is no need to make a clone. Switch of the direction of the chain can be made with the align function. It looks like the functionality of true and false is flipped for the X-Z plane compared to the other planes. Also placement has a lot if toys for placing the elements.
I think you mean that the behavior in the XZ plane is as expected. It is NOT logical to me in the other planes since the base object in the array is rotated 90 deg when the PathArray is applied with Align/True.Willem wrote:I agree that behavior in X-Z plane is not logical.
Thanks for pointing that out. It seems that the False condition is as expected for all planes, but the True condition only behaves as I would expect in the XZ plane.Willem wrote:Switch of the direction of the chain can be made with the align function.
Can anyone confirm this as a bug or is it by design?
- wandererfan
Wrong again.wandererfan wrote:PathArray doesn't know that changing the Placement of a Sketch based object doesn't move it.
I looked into the code. The same math is applied to the Base object in all cases. In the XZ case, the Base is rotated too, but you need an asymmetric object to see it (effectively 90* around each axis).
It might be possible to tweak the math for special cases, but I haven't yet come up with a general solution for all base orientations that always results in sensible results.
Another possibility might be a parameter(s) to control the initial placement of the Base objects.
So, not a bug, but maybe a feature request.
wf
- XZPathArray.fcstd
- (36.13 KiB) Downloaded 78 times
Thanks wandererfan for looking into this in more detail and clarifying the behavior to be expected. Now that I know how it will always behave I can allow for it before applying the PathArray.wandererfan wrote:So, not a bug, but maybe a feature request.
- wandererfan
You're welcome, happy to help. Now that you are the official expert PathArray user, maybe you should consider updating the Wiki or making a tutorial!ppemawm wrote:Thanks wandererfan for looking into this in more detail and clarifying the behavior to be expected. Now that I know how it will always behave I can allow for it before applying the PathArray.wandererfan wrote:So, not a bug, but maybe a feature request.
I am currently working on a spreadsheet driven model of a roller chain and two arbitrary sprockets for a client. Perhaps it can be shared when completed.wandererfan wrote:you should consider updating the Wiki or making a tutorial
I have an approximation, but it has a small error. The chain links, rollers, and pins can be exactly aligned for a given path and number of links, but the rollers do not align perfectly with the sprocket teeth. The rollers should follow the pitch circle of the sprockets. The reason for the error appears to be that only one point on the link (determined by the sketch origin) can be located on the path ,whereas in order to align with the sprocket teeth, the links need to align two points on the path. You can see the small error in the following picture: The centroid of the link is located at the origin of the link sketch which minimizes the error in this example. The link sketch itself is located at the global origin. If you try to align one end of the link then the links do not align to each other although the rollers can be exactly aligned with sprockets.
I am still searching for a workaround.
Let r be the radius of your placement path and l the length of one chain segment. You can reduce the radius by 1/2*sqrt(4 * r^2 - s). This is one of the forumlae for a circle's segment.
If you want some geometric (i.e. FreeCAD)-solution, can you post a simplified model?
Yeah had tried that already, it works great, but only if both sprockets have the same radius. I need a more general solution.chrisb wrote:You can reduce the radius by 1/2*sqrt(4 * r^2 - s).
