I am a pretty big noob when it comes to CAD software, but willing to learn .
So I am making a model of an 20kV cable for a later FEM simulation. For that I created a bunch of cylinders which looks pretty good so far. But now I need to create a small hole on the side of the cable. By using logical operations I managed to combine and cut out the necessary parts. The only problem I am facing is, that the once single piece cylinder is now a two piece cylinder. I made a bunch of screenshots highlighting my problems. Especially on the last one you can see that I can only look through the first layer, but I need to look down all the way through to the most inner cylinder. So is there a way for me to join these cylinders again?
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Join two Cylinders
Join two Cylinders
- Unbenannt.PNG (5.26 KiB) Viewed 1557 times
- Unbenannt1.PNG (14.52 KiB) Viewed 1557 times
- Unbenannt2.PNG (19.74 KiB) Viewed 1557 times
- Unbenannt3.PNG (3.38 KiB) Viewed 1557 times
- Unbenannt4.PNG (1.33 KiB) Viewed 1557 times
Re: Join two Cylinders
Did you pocket through all? Can you attach the model, possibly stripped down to show nothing more than the problem?
Thanks for the reply chris. I attached the model file. If you look at the small cylinder in the middle there, you will see that there are two of them. What I need is to join them together so I have only one, enabling me to look right at the center cylinder in the middle from the outside.
- model_simple_fault_1.FCStd
- (104.16 KiB) Downloaded 30 times
The screenshots show correct what you designed in Freecad. The line you highlighted in sketch UNBEKANNT2 SHOWS the cylinder with a radius of 9 mm you fused with cylinder76. This tiny cylinder is a hole that goes from the center on one side through the cable.
You can clone the small cylinder and subtract it from Zylinder004. To get an inner layer you could make a union of all these subcylinders Zylinder003-Zylinder075.
I know that it is embarrassing if you ask a question and you are overwhelmed with a complete redesign. But you might want to redesign at least the circle of 72 cylinders by using a polar array.
If possible, fuse the things together you want to keep. Fuse the things togehter you want to cut. And then make the cut.
Exactly, but if you look at the last pic I posted I am not able to see down to the center conductor. From the outside I am only able to see through Cylinder002. Cylinder001 seems to ignore the cut and blocks the view.Willem wrote:The screenshots show correct what you designed in Freecad. The line you highlighted in sketch UNBEKANNT2 SHOWS the cylinder with a radius of 9 mm you fused with cylinder76. This tiny cylinder is a hole that goes from the center on one side through the cable.
@chris: Ok, I will look into polar arrays.
Thanks so far everyone!
