I am learning Freecad and designing this (please see attached file). I dont know how to do it correctly. I need to push face inside with equal wall thickness and one side should be slanted. I used chamfer to get a face slanted but it need at least 1 mm width from bottom face.
Can you please guide me or any other way to do it correctly?
Adding Freecad version info:
OS: Mac OS X
Version: 0.16.6706 (Git)
Branch: tag: 0.16.6706
Python version: 2.7.11
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
Help needed to done some feature correctly
- push_a face_inside.FCStd
- (19.25 KiB) Downloaded 24 times
Re: Help needed to done some feature correctly
You could use the Thickness command from Part Working Bench.
Besides:
- you should completely constrain your sketches
- you should use the "reversed" pad only if necessary, it is clearer.
If you would like to have the chamfer going right to the bottom you would have attached a sketch to the side of the small block and pocket all through,
Besides:
- (13.91 KiB) Downloaded 23 times
Thank you for your reply. I created another version where I used loft and thickness, but how can I get rid of rounded edges resulted from thickness tool?
Also, I created two sketches 5 mm distance apart on z-axis, one larger rectangle and another one smaller to used in loft process. Is there a way I can create coincident constraint for two point based on 2d space so that point can freely move in 3rd axis?
Thank you.
Thank you.
- design_v2.FCStd
- (76.3 KiB) Downloaded 22 times
Thickness: use join type "intersection" instead of arc. Watch out: if you reopen the dialog it always shows the standard selection rather than the one you chose before. You can edit the parameters in the data tab below the tree.
Often there are other ways than using loft to model your object. You may show us what you want to achieve (scanned handdrawing, ...) and we will try to help.
In the current stable version 0.16 you cannot do that, but in the development version 0.17 it is possible. You may try that version but be aware that it has not yet reached the maturity of 0.16.shivmsit wrote:Also, I created two sketches 5 mm distance apart on z-axis, one larger rectangle and another one smaller to used in loft process. Is there a way I can create coincident constraint for two point based on 2d space so that point can freely move in 3rd axis?
I am getting error if I choose "joint type" to intersection for loftchrisb wrote:
I do not have drawing. I am learning by re-creating design based on some stl file that I am using for 3d print. For your reference I am attaching screenshot and stl file. You can checkout original project at http://www.instructables.com/id/Otto-Bu ... Two-Hours/. This would be good learning experience to create and improve original design in Freecad.
- example.png (30.24 KiB) Viewed 1200 times
Looking at the parts of the robot I cannot see a part similar to yours. Which one are you trying to model?
I think they have updated the parts I tried to attach file but got an error "File too large". I am sharing it on drop box https://dl.dropboxusercontent.com/u/506 ... leg_v2.stl.chrisb wrote:Looking at the parts of the robot I cannot see a part similar to yours. Which one are you trying to model?
Basically you have a cube with several cutouts an addons. And that is the way I would model it. Take a cube, hollow e.g. it with thickness, cut the holes with skecth and pocket, add your part at the inside (since you have it already) or construct it anew. Apply fillets or chamfers.
There are excellent tutorials on the website or video tutorials on youtube (e.g. search for bplrfe) which I recommend to work through! It helps learning to think like a 3d-modeler, and that's important.
