Perspective Viewport Properties
mcolinp
Postby mcolinp » Sun Oct 23, 2011 5:12 pm
Am I missing something or is there no way to adjust the Perspective Camera Properties. Most CAD programs have a way to adjust the Lens properties which make more or less skew in relation to say a wide angle lens or a normal say 50mm lens. I find the default perspective to be way to wide angle and blown out. Would like to be able to change this.
Site Admin
Re: Perspective Viewport Properties
Postby wmayer » Mon Oct 24, 2011 9:07 am
Check out the documentation for the class SoPerspectiveCamera
With our python interface you're able to change some settings there. As start point you can use this line:
from pivy import coin
camera=Gui.ActiveDocument.ActiveView.getCameraNode()
camera.heightAngle.setValue(...)
But make sure that you have switch to perspective mode before.
HoWil
Postby HoWil » Fri Apr 21, 2017 12:55 pm
Looks like the option heightAngle is no more accessible. Is there in the meantime something easier to change the viewangle directly in Freecad?
lg
HoWil
DeepSOIC
Postby DeepSOIC » Fri Apr 21, 2017 1:30 pm
HoWil wrote:Looks like the option heightAngle is no more accessible.
Works here:
Version: 0.17.10665 (Git)
Hash: 47847513a85ff6615774ef628230f79e37471daf
Python version: 2.7.8
OCC version: 7.0.0
Note:
* camera.heightAngle attribute is not listed in autocompleter, you have to type it in manually. This isn't the only place where it happens btw, but attributes of coin nodes are especially well hidden. They don't appear in dir(camera) and camera.__dict__.
* angle is in radians.
HoWil
Postby HoWil » Sat Apr 22, 2017 8:00 pm
DeepSOIC wrote:Note:
THX. All I needed to know :D !
