Have you tried Menue --> Edit --> Box Selection ?HoWil wrote:Is there maybe also a command for selecting a face/domain via coordinates or an intersecting box?
Select inner faces as FEM boundary
Re: Select inner faces as FEM boundary
Thanks for the suggestion but 'Box Selection' selects the body named 'Body' and the solid called 'Sphere' (see also picture from the first post) and lists them in the selection view.bernd wrote:Have you tried Menue --> Edit --> Box Selection ?HoWil wrote:Is there maybe also a command for selecting a face/domain via coordinates or an intersecting box?
Does anyone know which command is used for 'Box Selection' and are there maybe some additional settings like 'select only faces', since there is no command listed in the 'Python console'.
Oh yeah this would be really really usefull for FEM, to have the clipping plane in an separate dock widget. In all fem objects with reference shapes the clipping plane can not be used, although it is such a cool tool.ickby wrote: use clipping planes. Go to View->clipping Plane and than simply select the inner face. However, as the plane settings open in the tasks panel and all clipping planes vanish on close it cannot be used parallel to annother open task. so this only works if it is enough to preselect a face before running a fem tool.
My FreeCAD TODO list has been started to never end tooickby wrote:It is a point on my neverending list to make the cpliping planes a own dock widget, but I dod not yet manage to find the time for it.
Some questions from somebody who wants to get more insight into this topic to simply learn coding for FC:ickby wrote:Hello,
I think the only option you have is to use clipping planes. Go to View->clipping Plane and than simply select the inner face. However, as the plane settings open in the tasks panel and all clipping planes vanish on close it cannot be used parallel to annother open task. so this only works if it is enough to preselect a face before running a fem tool.
So I assume that it is written in C++ and can not be easily used without the task panel, or am I wrong? If it would be accessible via python what would I have to do to make a macro out of it? Can I start a macro while I am using a face-selection-Task-dialog in FEM-WB?
Maybe a separate 'tool' for finding all elements including hided faces, solids, etc. below the cursor (perpendicular to the screen surface) and a dialog to choose/select from these found elements could help. I made a mockup to illustrate this idea.
related to the last topic on developers part of the forum: viewtopic.php?f=10&t=19072
Hi ickby,ickby wrote:Hello,
Any progress on this? Would it help to write a feature request ?
BR,
HoWil
