hidden lines are really hidden
ariane_tux
Post by ariane_tux »
while playing a little bit with the "Drawing Modul" I observed that there are some lines missing:
1) create a box
2) create a Cylinder in the middle of the box
3) cut box and cylinder (box with a hole)
4) create a page (A3)
5) create a view (show hidden lines and and look at a solid side)
=> there is only 1 hidden line, instead of 2 hidden lines
I have uploaded a example file to http://www.spranger.biz/~bene/test_drawing.fcstd
ATTENTION: freecad crashes!
but that is for something complete different...
Founder
Re: hidden lines are really hidden
Post by wmayer »
Hi Bene,
Hm, I'm not sure if this is a bug. This depends on what the hidden-line-removal algorithm is supposed to do. If you select the cut feature, put it into the same direction as in the SVG and set its display mode to wireframe you'll see only one edge of the cylinder. But I think as normal user one assumes that the silhouette of the cylinder is used instead of its wireframe representation.
But I guess it's clearly a bug that the line inside the cube is broken.
Cheers,
Werner
bene42
Post by bene42 »
Hi Werner,
I thought more in the Direction of a technical drawing, like a drill hole. In a projection (with hidden lines) I estimate somethink like this:
Regards,
Bene
ariane_tux
Hi Werner,
played a little bit. I don't think the following patch solves all problems, but it produces
IMHO better drawings (blueprint in mind).
Patch: http://www.spranger.biz/~bene/0001-show ... ines.patch
Regards
Bene
Founder
Post by wmayer »
Hi Bene,
thanks for the patch again. Yes, this improves this issue a lot.
Cheers,
Werner
