dxf splines with ezdxf (python)
I need to open some dxf files with freecad, what usually works except one of them which is done with 'ezdxf' python module and contains a spline.
Can please somebody help me ? (It would be fine to do with freecad but, if it is necessary, I can do it too with an other software, but which ?)
Thanks and best regards,
amka
OS: Debian GNU/Linux 8.6 (jessie)
Version: 0.16.
Build type: None
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
my python script :
import ezdxf
dwg = ezdxf.new('AC1015') # splines requires the DXF R2000 format or later
fit_points = [(0, 0, 0), (750, 500, 0), (1750, 500, 0), (2250, 1250, 0)]
msp = dwg.modelspace()
msp.add_spline(fit_points)
dwg.saveas("ezdxf_spline.dxf")
amka
Version: 0.16.
Build type: None
Qt version: 4.8.6
my python script :
import ezdxf
- ezdxf_spline.dxf
- (16.13 KiB) Downloaded 116 times
Re: dxf splines with ezdxf (python)
Freecad works with DXF version R12. Your DXF file is probably made with a newer version. What I did is open the DXF file in Librecad ( a good free 2d CAD program ) and saved it as an R12 file. Now the new file is imported in Freecad without problems
- ezdxf_spline_Willem.dxf
- (17.16 KiB) Downloaded 93 times
My script does a R2000 version which is newer than R12, that's true. Thanks for the information, but...
How did you please do your file ? Impossible for me to open my own dxf with libreCAD, what I already tried.
- mylibrecadversion.png (57.87 KiB) Viewed 3194 times
I have a newer Librecad
Version: 2.2.0-alpha
Compiler: GNU GCC 5.4.0
Compiled on: Dec 30 2016
Qt Version: 5.5.1
Boost Version: 1.58.0
System: Ubuntu 16.04.1 LTS
Qt Version: 5.5.1
FreeCAD SAVES as R12, but opens normally any DXF file of any version (the format is incremental, so even newest versions should work). The new C++ importer still doesn't support splines, though, so you'll need to use the legacy importer (set that in the DXF preferences).
Hi
@ Yorik, I checked in both version 0.16 and 0.17
The original ezdxf_spline.dxf file imported in Freecad creates in the Combo view a name, but no elements. It is empty
The in Librecad opened and saved as R12 ezdxf_spline_Willem.dxf file creates name and elements.
I work with the legacy DXF-importer. I also tried to modify the file with TeighaConverter and that also failes
Ok there was a bug in the dxf importer, this is fixed with git commit 5d2e834bc3
Yorik, thank for fixing the bug before it is posted as a bug . I am now busy redecorating my kitchen but I will try this fix asap
Thanks for replies and... I see 'src' on the path for the fix... Have I then please to compile FreeCad if I want to open my dxf ?
amka
amka
Yes, or, wait for someone to compile for you
