dxf splines with ezdxf (python)
Re: dxf splines with ezdxf (python)
In some weeks I will need this fix, so I wonder if :
1. I have to do ALL this : http://www.freecadweb.org/wiki/CompileOnUnix (with the bug fix in the source).
2. Is it perhaps possible to do more simple ? Will the 0.17 come please soon ?
Best regards
amka
Best regards
amka
1. yes (when you pull from the FreeCAD git repo the fix is already in the sourceamka wrote:Hi,
Best regards
amka
2. give it a try first. 0.17 is not slated for anytime soon.
amka wrote:Have I then please to compile FreeCad if I want to open my dxf ?
FreeCAD now offers occasional appimages for the development version.yorik wrote:Yes, or, wait for someone to compile for you
Download the latest appimage (currently FreeCAD-0.17.git201703220057.glibc2.17-x86_64.AppImage) make the file executable and run FreeCAD.
https://github.com/FreeCAD/FreeCAD/rele ... g/0.17_pre
"fight the good fight"
Before run code, install ezdxf package to FreeCAD.
use PowerShell and change directort(cd) to ..\FreeCAD_0.17.10698_x64_dev_win\bin
and type
Double-Click to open FreeCAD and run code.
But I'm not sure spline in dxf and BSpline in FreeCAD are the same curve.
Version: 0.17.10698 (Git)
Hash: ac2f9f8902b67143ea081fedc9ffed86fc1a1bd3
Python version: 2.7.8
OCC version: 7.0.0
and type
./python -m easy_install ezdxf
import os
import Draft
import ezdxf
from FreeCAD import Vector
filePath, fileName = os.path.split(__file__)
drawing = ezdxf.readfile(filePath+os.sep+"ezdxf_spline.dxf")
modelspace = drawing.modelspace()
splines = modelspace.query('SPLINE')
Msg('n=%d\n'% len(splines))
points=splines[0].get_fit_points()
points2 = []
for i in points:
points2.append(Vector(i))
line = Draft.makeWire(points2,closed=False,face=False,support=None)
spline = Draft.makeBSpline(points2,closed=False,face=False,support=None)
bez = Draft.makeBezCurve(points2,closed=False,support=None)
#list(drawing.entities)
Msg('Done!\n\n')
OCC version: 7.0.0
Draft.makeBSpline( PTS ) creates an interpolating BSpline curve that goes through the PTS.But I'm not sure spline in dxf and BSpline in FreeCAD are the same curve.
So, in that case, PTS are not the control points of the BSplineCurve.
If you want to create a BSplineCurve from its control points, you should use :
bs = Part.BSplineCurve(pts)
Part.show(bs.toShape())
Dashed Line is made from Part.BSplineCurve.
It's the same makeBSpline().
import os
import ezdxf
import Part
import Draft
line = Draft.makeWire(points,closed=False,face=False,support=None)
spline = Draft.makeBSpline(points,closed=False,face=False,support=None)
bez = Draft.makeBezCurve(points,closed=False,support=None)
bs = Part.BSplineCurve()
bs.interpolate(points,False)
Msg('Done!\n\n')
Thanks you all and
Do you please know where I can find such a freecad for linux ?sgrogan wrote: FreeCAD now offers occasional appimages for the development version.
From my previous link this, file Direct Link to .AppImage Downloadamka wrote:Do you please know where I can find such a freecad for linux ?
https://github.com/FreeCAD/FreeCAD/releases/download/0.17_pre/FreeCAD-0.17.git201703220057.glibc2.17-x86_64.AppImage
Thanks, this Freecad works !
Thank you a lot for these informations !
My FreeCAD version is 0.16. Perhaps it is possible to do the same with the appimage (version 0.17) of the post before ?
Regards
And where have I to do this ? I did :chakkree wrote:Before run code, install ezdxf package to FreeCAD.
and typeCode: Select all
root@debian:/usr/lib/freecad/bin# ls -l
total 48
-rwxr-xr-x 1 root root 28368 mai 22 2016 FreeCAD
-rwxr-xr-x 1 root root 17256 mai 22 2016 FreeCADCmd
root@debian:/usr/lib/freecad/bin# python -m easy_install ezdxf
Searching for ezdxf
Best match: ezdxf 0.8.1
Adding ezdxf 0.8.1 to easy-install.pth file
Using /usr/local/lib/python2.7/dist-packages
Processing dependencies for ezdxf
Finished processing dependencies for ezdxf
Can you please explain me where to put this code ? I don't understand.chakkree wrote: Double-Click to open FreeCAD and run code.
import os import ezdxf from FreeCAD import Vector filePath, fileName = os.path.split(__file__) drawing = ezdxf.readfile(filePath+os.sep+"ezdxf_spline.dxf") modelspace = drawing.modelspace() splines = modelspace.query('SPLINE') Msg('n=%d\n'% len(splines)) points=splines[0].get_fit_points() points2 = [] for i in points: points2.append(Vector(i)) line = Draft.makeWire(points2,closed=False,face=False,support=None) spline = Draft.makeBSpline(points2,closed=False,face=False,support=None) bez = Draft.makeBezCurve(points2,closed=False,support=None) #list(drawing.entities) Msg('Done!\n\n')
Regards
