Longtime FreeCAD tinkerer, but attempting to use it for more serious work. I need to produce a dimensioned drawing for a machinist and thought I'd try out the new TechDraw work bench to see how it compares to the dimension tools in the Draft workbench. I can get a draft view into my template but I can't seem to select any edges or objects for adding dimensions, so the dimension icon remains grayed out. I don't think this is a bug, it's just me not being able to figure it out, especially with the limited documentation.
Any idea what I'm doing wrong? Once my draft view is in the template how do I add dimensions to it in the TechDraw workbench? File attached.
Using 0.17 daily build:
OS: Ubuntu 16.04.1 LTS
Version: 0.17.9586 (Git)
Build type: None
Hash: 0e2cf2ebcaaa50723de608cf030af740cb6ad548
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Can't add dimension to Draft View in TechDraw workbench
- techdraw-test.fcstd
- (19.67 KiB) Downloaded 44 times
Re: Can't add dimension to Draft View in TechDraw workbench
At the moment, dimensions cannot be added to a Draft View, because to add dimensions you first need to select vertices or edges, and you can't select anything on a Draft View.
Dimensions can only be added to these type of views:
These view tools do not seem to support wires, which is what your Draft objects are.
But there's a way: a Draft object is a high-level object that also has a "Make Face" property, which means that you can turn them to faces, if they are closed profiles (obviously, a Draft Rectangle or a Draft Circle can create a face, while an open DWire can't). And faces seem to be recognized by "View" and "Multi". So what you need to do:
- Select your Draft objects in the Model tree
- Under the Data tab, set the "Make Face" property to true
- Create either a View or a Multi view:
- If creating a view, you will need first to create a compound of all your Draft object from the Part --> Make compound menu in the Part workbench. Then create a view of the compound.
- With a Multi view, you just need to select all your Draft objects.
- Add dimensions to your view by making your selection first, then clicking on the desired dimension tool. For example, select a vertical edge then click on the vertical dimension tool; or select a circle and add a radius or diameter dimension. You can also select two points, or a circle's centre cross and a point.
- techdraw-test_normandc1.fcstd
- (23.65 KiB) Downloaded 42 times
- wandererfan
Draft (and Arch) views are converted to SVG before being given to TechDraw so there is no geometry to work with. But as @NormandC said, you can add the objects to the drawing by selecting Circle,Rectangle and Circle001, then adding a MultiView. You lose Draft's fancy formatting, though.system80 wrote: I don't think this is a bug, it's just me not being able to figure it out, especially with the limited documentation.
@NormandC, you should be able to add dimensions to Section and Detail also. If you cannot, let me know.
wf
- system80.png (21.76 KiB) Viewed 2691 times
That work around is doing the trick. Thank you so much for the assistance!!!
We need to attack that issue at some pointwandererfan wrote:Draft (and Arch) views are converted to SVG before being given to TechDraw so there is no geometry to work with.
Of course, I just didn't think of these two new tools because I have yet to use them.wandererfan wrote:@NormandC, you should be able to add dimensions to Section and Detail also. If you cannot, let me know.
Although Section does not appear relevant to 2D geometry.
