[Solved] Tech Draw - Hide "mm" behind dimensions - Add customizable extension line width
1. Tech Draw would look cleaner to me, if one can choose to omit the "mm" behind each dimension.
2. An option to change the width of the extension lines would be useful.
3. This extension line should also be displayed by default.
4. Center-snap of a dimension value on the extension line
The extension line is the line between the arrows of a dimension.
What do you think of these ideas?
- wandererfan
Re: Tech Draw - Hide "mm" behind dimensions - Add customizable extension line width
1) already done. see preferences tab 2.nokian wrote:1. Tech Draw would look cleaner to me, if one can choose to omit the "mm" behind each dimension.
2) you mean line weight? already done. see properties.
3) done for linear dimensions. Diameter sometimes overlays the text on top of the line. Have to fix that one day.
4) the value starts in the centre of the line (except for Radius leader). What do you mean by "Center-snap"?
That's not how I learned it, but that was many years ago. - From http://www.me.umn.edu/courses/me2011/ha ... orial.htmlThe extension line is the line between the arrows of a dimension.
wf
Thanks for your work on this module.
Well, okay so I meant the dimension line. I use the 0.17.9508 (Git) version.
When there is no place for the dimension to fit between the real "extension lines" the dimension line is hidden partly.
I think there should be a line between the extension lines.
Have a look at the 1 mm dimension in this example: http://www.joshuanava.biz/engineering/i ... nsions.png
By "center-snap" I mean an area around the mid-position where the mouse pointer dragging the dimensions gets caught to the center. But that's not important.
- wandererfan
So you're saying the red bit should be part of the Dimension line in the "doesn't fit" case? Is that an artistic suggestion or is that what the standards say? I don't' have ready access to a standards manual, but I've seen it done both ways.nokian wrote:When there is no place for the dimension to fit between the real "extension lines" the dimension line is hidden partly. I think there should be a line between the extension lines.
Perfect, that's what I'm used to. I don't know if there is any ISO rule or similar thing.
This may be from the ISO standard, but I don't think the interior of the extension lines is filled in ANSI standard. I'll check at work on Monday... if I don't forget it.
@wandererfan, I think at some point you may have to offer separate technical drawing standards to be chosen in the TechDraw preferences. ISO and ANSI are the most common, but there are others like JIS (Japan) and Russia has its own as well. The trick will be to get the full spec for each one...
For example, in ANSI I believe it's more common to see the dimension text in the middle of the dimension line (effectively breaking it in half - in fact, exactly like shown in your DimTerm.jpeg image) than over it.
- wandererfan
maybe not for 0.17?NormandC wrote:@wandererfan, I think at some point you may have to offer separate technical drawing standards to be chosen in the TechDraw preferences. ISO and ANSI are the most common, but there are others like JIS (Japan) and Russia has its own as well. The trick will be to get the full spec for each one...
Hey, I did say "at some point", which gives you some leeway.wandererfan wrote:maybe not for 0.17?
I will be ecstatic with TechDraw even if there is no improvement to it from now on until the official 0.17 release.
If useful search by google "bs iso 129-1".wandererfan wrote:So you're saying the red bit should be part of the Dimension line in the "doesn't fit" case?nokian wrote:When there is no place for the dimension to fit between the real "extension lines" the dimension line is hidden partly. I think there should be a line between the extension lines.
There is a "good pdf"...
At point "5.6.3 Special positions of dimensional values " it says:
Also look at Annex A for "Relations and dimensions of graphical symbols"."b) dimensional values can be shown on a reference line, and attached to the dimension line by a leader line,
terminating on the dimension line that is too short for the dimensional value to be indicated in the usual
way between the extension lines (see Figure 25); "
Marco_T
Marco was faster than me
from the same source, I add
Renato
Also, there are ANSI standards.a) dimensional values can be above the extension of the dimension line beyond one of the terminators, if
space is limited (see Figure 25);
Renato
