See the screenshots and attached FCStd file. If you fuse the 10 objects together it has a bug in 0.15 and 0.16 release versions. Also MacroForceRecompute goes wrong.
Can someone with a working 0.17 latest build preferably have a look whether it goes ok there?
Note i found after some hours a solution here to be able to continue the CAD work. The largest cube, if i extend it downwards 1 millimeter in size, then after recalculation 0.16 goes ok then, 0.15 has bug then.
fusion bug - does this work ok in 0.17?
Re: fusion bug - does this work ok in 0.17?
I didn't have a problem in 0.16 so I didn't try or 0.17.
OS: Ubuntu 16.04.1 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Version: 0.17.9542 (Git)
Build type: None
Hash: 96dc57c06861922b9dde830e3bcc07e43ed11cf7
Build type: None
Build type: None
That's most interesting as i have 0.16.6706 here - windows x86 though.
Related? issue #2845
Works here:
OS: Mac OS X
Version: 0.17.9586 (Git)
Branch: (detached from 0e2cf2e)
Hash: 0e2cf2ebcaaa50723de608cf030af740cb6ad548
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 7.0.0
and here:
OS: Mac OS X
Version: 0.16.6706 (Git)
Branch: tag: 0.16.6706
Python version: 2.7.11
Coin version: 3.1.3
OS: Mac OS X
Coin version: 3.1.3
OCC version: 7.0.0
and here:
OS: Mac OS X
Coin version: 3.1.3
Which file, the one posted by diep or the one in issue #2845, or both?chrisb wrote:Works here:
It looks like the problem in issue #2845 is where the blades intersect at the top faces and create triangular edges: Creating a Fusion of only the blades took a while, so I tried again with only two blades. That passed Check Geometry with BOPCheck = True but the resulting Fusion001 isn't as expected - most of one blade disappeared.
Build type: None
issue #2845 is a typical issue with OCC. All the parts share the same edge at the centre of rotation, with Booleans this is almost always a certain recipe for failure. The situation can easily be avoided by removing the condition, it's been discussed repeatedly for years on the forum and issue #2845 should never have been created in the first place, as explained in the "READ THIS BEFORE REPORTING" menu entry that links to the bug reporting guidelines on the forum.
I tried the one posted by diep and it was ok.bejant wrote: Which file, the one posted by diep or the one in issue #2845, or both?
issue #2845 does not work on any of the both versions.bejant wrote: Which file, the one posted by diep or the one in issue #2845, or both?
