Every time i try to pad this sketch I am having FreeCAD crash on me.
The origin of this sketsh is from the wire witch is taken from an imported iges file from https://github.com/seemecnc/Rostock-MAX ... 0Plate.IGS and Draft:Draft<->Sketch
I get the following complaint when trying to pad, clicking ok leads to segmentation fault.
(gdb) run
Starting program: /usr/bin/freecad
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
FreeCAD 0.17, Libs: 0.17R9592 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2016
[New Thread 0x7fffd622d700 (LWP 32451)]
[New Thread 0x7fff95720700 (LWP 32452)]
[New Thread 0x7fff94865700 (LWP 32453)]
[New Thread 0x7fff8ec33700 (LWP 32454)]
[New Thread 0x7fff8e432700 (LWP 32455)]
[New Thread 0x7fff8db8a700 (LWP 32456)]
Can't find Origin for "Body"
[New Thread 0x7fff73fc4700 (LWP 32457)]
[New Thread 0x7fff737c3700 (LWP 32458)]
[Thread 0x7fff73fc4700 (LWP 32457) exited]
[New Thread 0x7fff72fc2700 (LWP 32459)]
[Thread 0x7fff737c3700 (LWP 32458) exited]
[New Thread 0x7fff727c1700 (LWP 32460)]
[Thread 0x7fff72fc2700 (LWP 32459) exited]
[New Thread 0x7fff71fc0700 (LWP 32461)]
[Thread 0x7fff727c1700 (LWP 32460) exited]
[New Thread 0x7fff717bf700 (LWP 32462)]
[Thread 0x7fff71fc0700 (LWP 32461) exited]
[New Thread 0x7fff70fbe700 (LWP 32463)]
[Thread 0x7fff717bf700 (LWP 32462) exited]
[New Thread 0x7fff707bd700 (LWP 32464)]
[Thread 0x7fff70fbe700 (LWP 32463) exited]
[Thread 0x7fff707bd700 (LWP 32464) exited]
[New Thread 0x7fff707bd700 (LWP 32465)]
[New Thread 0x7fff70fbe700 (LWP 32466)]
[Thread 0x7fff707bd700 (LWP 32465) exited]
[New Thread 0x7fff717bf700 (LWP 32467)]
[Thread 0x7fff70fbe700 (LWP 32466) exited]
[New Thread 0x7fff71fc0700 (LWP 32468)]
[Thread 0x7fff717bf700 (LWP 32467) exited]
[New Thread 0x7fff73fc4700 (LWP 32469)]
[Thread 0x7fff71fc0700 (LWP 32468) exited]
[New Thread 0x7fff737c3700 (LWP 32470)]
[Thread 0x7fff73fc4700 (LWP 32469) exited]
[New Thread 0x7fff72fc2700 (LWP 32471)]
[Thread 0x7fff737c3700 (LWP 32470) exited]
[New Thread 0x7fff727c1700 (LWP 32472)]
[Thread 0x7fff72fc2700 (LWP 32471) exited]
[Thread 0x7fff727c1700 (LWP 32472) exited]
[Thread 0x7fff8e432700 (LWP 32455) exited]
[Thread 0x7fff8db8a700 (LWP 32456) exited]
[New Thread 0x7fff8db8a700 (LWP 32473)]
[New Thread 0x7fff8e432700 (LWP 32474)]
[New Thread 0x7fff727c1700 (LWP 32475)]
[Thread 0x7fff8e432700 (LWP 32474) exited]
[Thread 0x7fff8db8a700 (LWP 32473) exited]
[New Thread 0x7fff72fc2700 (LWP 32476)]
[New Thread 0x7fff73fc4700 (LWP 32477)]
[Thread 0x7fff72fc2700 (LWP 32476) exited]
[New Thread 0x7fff737c3700 (LWP 32478)]
[Thread 0x7fff73fc4700 (LWP 32477) exited]
[New Thread 0x7fff6f10f700 (LWP 32479)]
[Thread 0x7fff737c3700 (LWP 32478) exited]
[Thread 0x7fff727c1700 (LWP 32475) exited]
[New Thread 0x7fff6e90e700 (LWP 32480)]
[Thread 0x7fff6f10f700 (LWP 32479) exited]
[Thread 0x7fff6e90e700 (LWP 32480) exited]
Thread 1 "freecad" received signal SIGSEGV, Segmentation fault.
0x00007fff7425f80e in prepareProfileBased(Gui::Command*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function<void (Part::Feature*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)>) () from /opt/freecad/lib/PartDesignGui.so
(gdb) bt
#0 0x00007fff7425f80e in prepareProfileBased(Gui::Command*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function<void (Part::Feature*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)>) () at /opt/freecad/lib/PartDesignGui.so
#1 0x00007fff7425fb89 in CmdPartDesignPad::activated(int) () at /opt/freecad/lib/PartDesignGui.so
#2 0x00007ffff7400b7c in Gui::Command::invoke(int) () at /opt/freecad/lib/libFreeCADGui.so
#3 0x00007ffff5410c50 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) ()
at /usr/lib/libQtCore.so.4
#4 0x00007ffff5964082 in QAction::triggered(bool) () at /usr/lib/libQtGui.so.4
#5 0x00007ffff59653e3 in QAction::activate(QAction::ActionEvent) () at /usr/lib/libQtGui.so.4
#6 0x00007ffff5d402f3 in () at /usr/lib/libQtGui.so.4
#7 0x00007ffff5d40444 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) () at /usr/lib/libQtGui.so.4
#8 0x00007ffff5e05a7a in QToolButton::mouseReleaseEvent(QMouseEvent*) () at /usr/lib/libQtGui.so.4
#9 0x00007ffff59c0840 in QWidget::event(QEvent*) () at /usr/lib/libQtGui.so.4
#10 0x00007ffff5969f2c in QApplicationPrivate::notify_helper(QObject*, QEvent*) () at /usr/lib/libQtGui.so.4
#11 0x00007ffff59725b7 in QApplication::notify(QObject*, QEvent*) () at /usr/lib/libQtGui.so.4
#12 0x00007ffff73d6a80 in Gui::GUIApplication::notify(QObject*, QEvent*) () at /opt/freecad/lib/libFreeCADGui.so
#13 0x00007ffff53fcb2d in QCoreApplication::notifyInternal(QObject*, QEvent*) () at /usr/lib/libQtCore.so.4
#14 0x00007ffff59705db in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () at /usr/lib/libQtGui.so.4
#15 0x00007ffff59eba89 in () at /usr/lib/libQtGui.so.4
#16 0x00007ffff59ea43c in QApplication::x11ProcessEvent(_XEvent*) () at /usr/lib/libQtGui.so.4
#17 0x00007ffff5a12db2 in () at /usr/lib/libQtGui.so.4
#18 0x00007fffed92a587 in g_main_context_dispatch () at /usr/lib/libglib-2.0.so.0
#19 0x00007fffed92a7f0 in () at /usr/lib/libglib-2.0.so.0
#20 0x00007fffed92a89c in g_main_context_iteration () at /usr/lib/libglib-2.0.so.0
#21 0x00007ffff542cece in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) ()
---Type <return> to continue, or q <return> to quit---
Version: 0.17.9592 (Git)
Hash: c2f2a250549163947592069262ce1cd3328b3669
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.9.1
