Path module fails to generate path on my parts
Hello, it's me again, again with my guitar.
This time I am trying Path workbench. First I tried it with simple cubes and holes, it worked with no visual problems, but when I tried my guitar body, it failed, unfortunately.
Most interesting result I get with "Profile based on faces". Then I see the path is wrapping here and there while I'm adding faces. very strange behaviour.
I know, Path workbench is in development, and so on, but maybe you need an example of complex shape? Here it is
OS: "Manjaro Linux"
Version: 0.17.9748 (Git)
Hash: ad57478ab43308fce12035e07b4b9b2b4670774d
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.9.1
OS: "Manjaro Linux"
Coin version: 3.1.3
OCC version: 6.9.1
- simplisied body.fcstd
- (32.88 KiB) Downloaded 27 times
Re: Path module fails to generate path on my parts
Study this tutorial https://www.youtube.com/watch?v=c4JUnB1AHdY. It give a lot of information about how to work with the path workbench. One major thing I understand from this tutorial is that you first define the tools you are going to use in the workshop and second the program will calculate the path for the CNC machining
Yes, thank you, already watched this tutorial and read documentation before start experimenting. And I successfully made paths with simple parts like cube, cylinder and so on.
On my part, that I attached, it just fails to generate path with "Contour path for the base object" . With "Profile based on faces" tool it can generate path for the first selected face. But If I add more faces, then it stops on first one, or generates weird paths going from outside to inside, or looping on one face.
I would glad if someone who develops this workbench to look at my model.
No, this is beautiful, I don't argue
- Screenshot_20170122_115914.png (121.77 KiB) Viewed 1662 times
It seems to be a regression problem:
I tried a profile based on edges:
It works here:
OS: Mac OS X
Version: 0.17.9586 (Git)
Branch: (detached from 0e2cf2e)
Hash: 0e2cf2ebcaaa50723de608cf030af740cb6ad548
Coin version: 3.1.3
OCC version: 7.0.0
Not working here:
OS: Ubuntu 14.04.5 LTS
Version: 0.17.9747 (Git)
Build type: None
Hash: f5c0f579cbd7ce668727f8835946e4e9abc0eec6
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
It works here:
OS: Mac OS X
Coin version: 3.1.3
OCC version: 7.0.0
Not working here:
Build type: None
Qt version: 4.8.6
But the problem might be (probably is) the model. It is over-constrained. This needs to be resolved before you go any further.
When you remove the constraint it recommends, you end up with 39 degrees of freedom. Probably not a good thing!
I was thinking about it, but it is a dirty hack for this exact situation, not as it should be.
Ya think !!!Konstantin wrote:I was thinking about it, but it is a dirty hack for this exact situation, not as it should be.
No thinking to be done. Correct, this should be a one-click to a PATH. This is not a solution. Its simply shows that path(s) can be generated for each segment. You need to address your model before moving on to generate a path; SPECIFICALLY the "Sketch" (fix the OVER-CONSTRAINED situation). bill, over and OUT!
This "OVER-CONSTRAINING" Is appearing and disappearing in random places from version to version If you remove one constraint, next time it can become unsatisfied with another, I am tired of satisfying solver.
And in any case it doesn't fix the problem with Path module. As you can see, chrisb said, he succeed to build one with older version of FreeCAD.
