Shoelast
microelly2
Re: Shoelast
Postby microelly2 » Fri Mar 31, 2017 9:47 pm
toward the scanned shoe:
https://youtu.be/u28heuCTUjk
so I ask for more test data
If there is somebody who whats to share his shoe last data with is project:
more test data for different shoelast layouts from reality will help to go into the right direction.
what we need is a scan (obj or stl) of the model.
kridhond
Re: Shoelast
Postby kridhond » Mon Apr 03, 2017 4:40 pm
I'll try to get an example this week. I expect it to be Friday.
microelly2
Re: Shoelast
Postby microelly2 » Wed Apr 05, 2017 1:08 pm
https://youtu.be/7gU2jaKNYUI
EDIT:
to make the work with the sketchers easier there was this idea :lol:
https://youtu.be/J4kD1LLP3uU
kridhond
Re: Shoelast
Postby kridhond » Fri Apr 07, 2017 7:15 pm
Hi again!
I tried to attach an stl-file of a shoelast but the file is too large (altough it's only 4Mb). I'll get the file to microelly2 in another way so soon you'll be seeing some pictures of it :-)
In a perfect world, that would be the output of the freecad-model with the following data (I refer to the parametric model I suggested some posts ago):
LL (last length) : 247 mm
H10 (heel rise) = 17 mm
Other parameters as default
Joint = 245 mm
Girth = 235 mm
Waist = 230 mm
Instep (around the heel) = 315 mm
Hope we can get to a working model. I'd love to do some real-life tests and feedback the results.
BR
microelly2
Re: Shoelast
Postby microelly2 » Wed Apr 12, 2017 9:02 pm
Thanks for the model, I have analysed the data and now we can see this model inside our model.
https://youtu.be/2xpaX3RPFi0
I will look next days (after easter) to reduce the ribs to our data model (from 90 to 14)
and hope to get a good enough approximation
microelly2
Re: Shoelast
Postby microelly2 » Thu Apr 20, 2017 10:17 pm
demo sketcher proxy to edit tangent/directions in two control points,
https://youtu.be/Lt5wDYsu4qA
With the next version of FreeCAD we can hide the blue data and then we have only an simpilfied drawing interface.
microelly2
Re: Shoelast
Postby microelly2 » Fri Apr 21, 2017 2:38 pm
Today I have looked how professional foot scanning works.
foot length and joint size are not very exact (or there is no shoe which fits the size of the scanned foot :lol: )
The idea is: green and yellow and red are easy to scan under rgb filters
the grid distances is about 5 mm
I'm now looking for such grid stockings ...
Re: Shoelast
Postby NormandC » Sat Apr 22, 2017 8:17 pm
kridhond wrote:I tried to attach an stl-file of a shoelast but the file is too large (altough it's only 4Mb).
4MB may not look much to you, but on an online forum that can see many images and files attached each day, it quickly adds up. The forum does not have unlimited hosting so a limit (currently 1MB I believe) has to be set.
That being said, an STL file can be compressed in ZIP format, it will greatly reduce its size.
microelly2
Re: Shoelast
Postby microelly2 » Mon Apr 24, 2017 6:17 pm
the curve length of the rib in colors: red > max , blue < min
https://youtu.be/JbVJSx8ccuU
