same as mine, only I moved some segmentschrisb wrote:Mine is again different, perhaps due to OS difference:
SVG to Solid (newbie question)
Re: SVG to Solid (newbie question)
Renato..
This is what the original DXF looks like on my system.. Attached is the SVG as per the original image.
Thanks for your help.
- outline.svg
- (6 KiB) Downloaded 29 times
Hello Mark,
Your DXF imports all the arcs as splines. They are listed under a Group (folder) labeled "0".
Did you go through Inkscape to get this DXF? It would be best to import DXF files "untainted" by a pass through a vector graphics program such as Inkscape because in my experience it sometimes exports circles and arcs as Bézier curves or BSplines. This complicates things.
To load DXF preferences, the Draft workbench needs to be loaded first, because it manages DXF/DWG import. Since it's a python module, for any change to take effect you need to restart FreeCAD.
Mine are shown in the attached screen capture.
No, it's probably due to different DXF import settings. There are quite many.chrisb wrote:Mine is again different, perhaps due to OS difference:
- FC016_DXF_Import-Export_Preferences_01.png (161.55 KiB) Viewed 1117 times
Hi Norman,
Thanks and following your advice I have imported directly into Freecad "untainted" and now have a file that only includes Lines and arcs.
In the draft workspace I have tried to "join" the lines and arc's but it seems to be behaving in an unpredictable way and for the life of me I can't get it to create a continuous line. Are there any steps I have missed out?
Thanks
Mark
Thanks
Mark
- top bracket.FCStd
- (42.85 KiB) Downloaded 23 times
Hello Mark,
The easiest and fasted method in my opinion is converting the Draft objects into a single Sketch.
From your file you can do that by selecting all objects; switching to the Draft workbench, click on the Draft Draft2Sketch tool.
Next, hide all the Draft objects and only keep the Sketch visible; switch to the Sketcher or PartDesign workbench; with the Sketch selected, go to either the Sketch or Part Design menu, and select "Validate sketch". In the Tasks panel, under "Missing coincidences", click on "Find"; a pop up dialog will tell you it found 45 missing coincident constraints; click OK, then in the Tasks panel, click on "Fix".
You now have a sketch that you can pad from the PartDesign Workbench. If you get a "Failed to validate face" error, it means there's a minute gap somewhere. Go back to the Validate sketch utility, and raise the tolerance value.
Hi Norman,
Thank you very much for your help and guidance. I know have a perfect 3D shape .
