Hello all.
I am trying to put a hole ("Sweep001") in the attached body ("Fusion008"). When I try to do the boolean difference function, the hole does not go through the body. I think there might be something wrong with the body (particularly the round part), in that all my attempts to export this to .stl have failed. Any insight would be appreciated, file and freecad info attached.
Thanks.
OS: Windows 7
Version: 0.16.6703 (Git)
Branch: releases/FreeCAD-0-16
Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Boolean difference function not working right
- Revision 2.stl
- (91.05 KiB) Downloaded 33 times
- Revision 2.FCStd
- (316.05 KiB) Downloaded 38 times
Re: Boolean difference function not working right
Please enable the "BOP Check" parameter and run Part->Check geometry on Fusion008. It shows several errors. You should track them down and eliminate them before doing further boolean operations.
