Hi
I am trying to draw a horn like a trumpeet, but I can not do the sweep. I have tested a lot of different ways, but failed.
In this drawing, I have drawn a Bezier line to do the shape. I test to do an offset of the Bezier line, but it will not work so I did a copy and connect the ends to a closed figure. Then I make wire and sketch.
But there is no sketch valid for revolving or anything else. What am I doing wrong?
Revolving Bezier curves
- Horn sweep-1.FCStd
- (3.13 KiB) Downloaded 24 times
Re: Revolving Bezier curves
Go to the Part WB (not PartDesign WB), select Wire from the history tree, and click the Revolve tool. If you want a solid tick the "Make Solid" box to True, or if you forget you can change the Property > Solid later from the Data tab.
Sketch is empty, there is nothing in it.
Let me add a bit to this:
In FreeCAD 0.16 Sketcher doesn't support Bezier curves (they were just added to Sketcher recently in 0.17), so if you created the Wire and then used the Draft WB > Bi-Directionally Convert tool, you'll end up with an empty Sketch. I'm guessing that's what you did? I'm also not sure that in 0.17 the Draft WB > Bi-Directionally Convert tool works with Bezier curves yet.Gustav180 wrote:But there is no sketch valid for revolving or anything else. What am I doing wrong?
Wow, it works. Thank you very much mr bejant. It is a bit confusig that same commands are in different wb or that some of them not will work, e.g. converting draft-wire to sketch.
