Failure to pad sketch drawn on a face which has the same shape
LeoTilson
Post by LeoTilson »
Forum users, Thank you for considering this. It appears to be an edge-case.
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
but it also appears on other versions of FreeCAD which are available to me, including version 0.17
Submitted as Bug Report here: https://freecadweb.org/tracker/view.php?id=2904
1) Open a new document in Part Design
2) New sketch - a teardrop. This consists of
a) An arc of about 270 degrees centred at the origin
b) A line with a horizontal constraint
c) A line with a vertical constraint
d) Where one of the lines joins the end of the arc include a tangential constraint.
3) Pad the sketch.
4) On the new face draw a second identical sketch. Choose the curved part of the sketch as external geometry.
5) Pad the second sketch
At this point we should have a teardrop twice the height of the first, but the model falls apart. The results of the operation are inconsistent, but, put succinctly, the Teardrop Explodes.
The first teardrop
The first teardrop
Sketch drawn on top face
Result of extruding the second sketch
Leo Tilson
LeoTilsonTest2.FCStd
The FSCAD file
(9.28 KiB) Downloaded 22 times
Re: Failure to pad sketch drawn on a face which has the same shape
No problem here:
OS: Ubuntu 14.04.5 LTS
Version: 0.17.10101 (Git)
Build type: None
Hash: 99fa203f323927b0dd027420d4421b577b7420c3
Python version: 2.7.6
Qt version: 4.8.6
teardrop_cb.fcstd
(15.76 KiB) Downloaded 25 times
cox
Post by cox »
Migrating the project file fixes the issue in :
OS: "Arch Linux"
Version: 0.17.9790 (Git)
Hash: 294b2308d660a4aae11e90ec22f96ca56190bcd1
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.9.1
Post by Kunda1 »
cox wrote:Migrating the project file fixes the issue
What does this mean?
sgrogan
Post by sgrogan »
Kunda1 wrote:What does this mean?
See duplicate thread https://forum.freecadweb.org/viewtopic.php?f=3&t=20721
"fight the good fight"
cox
Post by cox »
After opening the file in 0.17 dev the model is corrupted as explained in OP's post. Since this model was made in 0.16 it is possible to use Partdesign:Migrate function to upgrade the model to 0.17. Using this function fixes the model according to OP's expectations.
