I am new to FreeCAD (2 days in) and going up a very steep learning curve - the answer to this question may be obvious, but I cannot find it.
I want to be able to use master data from a spreadsheet to position some parts. The two ideas I had were:
1) use an expression in the translation vector data for the part
2) use an expression in the coordinate data for the Draft Move tool
however neither take expressions, only values.
A sketch can be positioned because constraints take expressions, but I do not think this allows more complex CSG objects to be moved.
Thanks for any help you can offer.
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Position part using spreadsheet value
Re: Position part using spreadsheet value
Hello.
Welcome to FreeCAD and the forum.
The coordinates of Cut/Fusion-Objects and Compounds can be controlled via spreadsheet ...
Roland
That depends.Trygon wrote:but I do not think this allows more complex CSG objects to be moved
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
The property editor does accept expressions for objects, hence their placements can be used with expressions there.
Thanks for your help. Sorry for the slow reply - CalculiX/Win 10 locked up and in the process wiped out part of my Win 10 front end.
I had not realised that there are two ways to access the Placement parameters for an object from the Combo View:
1) click on "Placement" then on the "..." button at the RHS, which opens the Tasks Placement window, where expressions cannot be entered
2) click on the ">" at the LHS of Placement to expand the data view, where expressions can be entered - as required
However it appears to me that method 2 does not give access to the rotation center...?
