Black & white view on save pciture
How can I get view white or white shaded with black lines as shown below easily without changing object colour.
Sample attached.
Sample attached.
- microelly2
Re: Black & white view on save pciture
If you want to change colors in 3D View you must change Line/Shape Colors of your models and background color too .
But the best solution would be to have a macro which exports the picture and postprocess the image.
once configured such a filter macro it's the fastest way.
You can create a drawing (or in v0.17 a TechDraw document).
- microelly2
It is still hard to create a perspective drawing with non default camera settings.chrisb wrote:You can create a drawing (or in v0.17 a TechDraw document).
You are right - of course. If arbitrary perspective matters drawings might be the wrong way.microelly2 wrote:It is still hard to create a perspective drawing with non default camera settings.chrisb wrote:You can create a drawing (or in v0.17 a TechDraw document).
There might be something in between, if it is only the background that matters. In the extended dialog for Tools->Save picture you can select a white background.
Thank you for the support. As suggested, I used 2d shape tool to generate drawing & exported.
How I adjust the dimension to match iso metric view? sample attached.
- sample 5.fcstd
- (5.27 KiB) Downloaded 81 times
Hello jaisejames,
Forget Shape2DView projections. Drawing is the way to go if you need to add dimensions to your view.
Here's your example with an added Drawing page.
- Create a Drawing page
- Create your view: what's easiest is to use Drawing Ortho views, create a front view as base view, then create an isometric as auxiliary view. Once your views are created, delete the ortho view and only keep the isometric one.
- Add Draft Dimensions to your 3D model
- Project those dimensions to the page easily by selecting the dimensions, selecting the drawing view, then clicking on the Draft View icon.
- sample 5_drawing_normandc1.fcstd
- (19.06 KiB) Downloaded 77 times
Thank you for support. Which option I need to adjust to change text orientation of text in dimension?. I checked in wiki. but I unable to understand.
On pdf export arrow goes out of dimension extension line as seen the attachment.
- 01.pdf
- (99.88 KiB) Downloaded 73 times
It looks like a bug to me, I was able to reproduce on Ubuntu.
Here's a workaround that requires use of another open source program:
- From the Drawing workbench, save your Page as SVG
- Install Inkscape
- Open the SVG in Inkscape
- Export to PDF
- sample 5_exported_from_Inkscape.pdf
- (6.98 KiB) Downloaded 92 times
Thank you for your support.
I tried with libreoffice but dimension text changes it's orientation. So I skipped svg. I try with inkscape.
