@ NormanC:
Now I tried to do it with the "real" Assembly2 workflow (at least I think I did). It didn't make a difference: my computer is now calculating some constraint since about 45 minutes and I only have 5 triangles added to the base. I think the Assembly tool isn't suitable for this kind of operation...
@ ulrich1a:
Thanks for the link! This might get helpful for constructing a geo dome in real life. However, I have to admit that if I really dig into the math of the Kruschke geo dome I would rather construct it in OpenSCAD for reasons of easy parameterization. I hoped that I could get around the whole math stuff by using an online calculator and using those values in FreeCAD.
Does anybody have another idea? I guess I have to give this project up otherwise...
Designing a geodome from scratch
Re: Designing a geodome from scratch
here's the file...
- geodome constraints1.fcstd
- (15.15 KiB) Downloaded 34 times
There exists a hidden version of the geodesic dome script. It contains the Kruschke-dome as default version. Have a look here: https://forum.freecadweb.org/viewtopic. ... 10#p125238
Ulrich
Ulrich
Hello Ulrich!
Your Script is really awesome. Thank you for that!
As far as I see it seems you made your hands dirty and calculated angle and every length that is needed for the geodome within your script, right? So you also didn't find a trick to let FreeCad snap everything together for you?
Thank you once again!
Best,
Marcel
Best,
Marcel
Yes, for a geodesic dome as a mathematical object, this approach seems the most efficient for me. And it was made a year ago or so.Spindoctor wrote:As far as I see it seems you made your hands dirty and calculated angle and every length that is needed for the geodome within your script, right?
Ulrich
Good job!
Thank you for your help. Maybe, if I somehow can generalise my problem I can make a feature request out of it...
