Union, Part become black.
I want do this boolean operate:
shell - ( Array + Cylinder002 + Cone )
but when I select Array + Cylinder002 + Cone, make union, the result Fusion001 become black color. no error shown. Of course when make cut, also black. That result not my wish one.
- tmp.fcstd
- (37.48 KiB) Downloaded 27 times
Re: Union, Part become black.
Hi, the problem is easy to solve, rotate the cylinder a bit and the fusion will succeed. This is a known bug in the OCC kernel
Nice one Willem.
P.S. Likely the seem edge was the cause?
thanks Willem.
strange but interesting bug. lol
btw: Your Unity side bar is too strong.
Which bug is this ? Can you reference it please? Thanks!Willem wrote:This is a known bug in the OCC kernel
I don't know if it's logged as a bug upstream. But seam lines of cylinders/spheres/tori are known to cause issues in Boolean operations when they align to each other (well-known cases are screw threads, there are at least a dozen of topics where Willem's trick fixed the issue). Surface tangency and coplanar faces are known issues as well.
It's mostly workarounds that we experienced users have found over time to bypass the kinks of the OCC kernel. Because of the way reports need to be made on the OCCT bug tracker, we have not reported it upstream (unless shoogen did at some point).
I know that we should document this on the wiki...
I agree NormandC, it a bug. OpenSCAD employs OpenCSG and OpenGL. and It never got error when doing Boolean operation, regardless of whether the target is aligned.
never as in this topic viewtopic.php?f=3&t=21215
Yes. Boolean operations are very sensitive to tangent and coplanar surfaces. A slight misalignment can make them fail.
Maybe not, but the OCC kernel is much more powerful than CGAL. OCC is a *real* CAD kernel.
Better efficiency, does not mean no bug.
Sure, openscad's render is too slow. In freecad seems no matter at rendering efficiency.
I was not referring to slowness (FreeCAD can be slow too!), but to actual functions. Try to make fillets or chamfers in OpenSCAD!
In any case it is more oriented toward programmers than CAD end users.
