Add parts to BooleanFragments
Is there a way to change the childs of BooleanFragments in part-Wb? I want to add or remove elements without deleting the existing BooleanFragments each time I have to change something and creating a new one.
BTW: I use BooleanFragments for building multibody-FEM-mesh-models. I have to change these models for different studies, that is why I need to change the BooleanFragments-elements.
The usual drag-n-drop to add something into a group is not working and there is no property in the Data-view where one could select/change the incorporated elements.
A python-console workaround would also be appreciated.
Thanks in advance,
HoWil
Thanks in advance,
HoWil
- microelly2
Re: Add parts to BooleanFragments
you can use a method in the open scad wb to replace components in a boolean tree
Hi, drag and drop works well in my design. The only thing is you have to recompute by running the macro "Forcerecompute" because this is not done automatically, or you have to go on with your design until it recomputes automatically
Hi microelly2,microelly2 wrote:you can use a method in the open scad wb to replace components in a boolean tree
this option is greyed out for me... see the attached screencast. Deleting works!
Hi Willem,Willem wrote:Hi, drag and drop works well in my design. The only thing is you have to recompute by running the macro "Forcerecompute" because this is not done automatically, or you have to go on with your design until it recomputes automatically
Drag and drop does not work for me... please see the screencast. Are you doing something similar? Which version of FC do you use?
Thanks in advance,
HoWil
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10460 (Git)
Build type: None
Hash: 91c59c7910436c44ede608e29d9a90a287121a11
Python version: 2.7.12
OCC version: 7.1.0
- DeepSOIC
I recently saw that drag-and-drop support is accessible to python, so I might have a crack at this.
Hi, my version:
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
OCC version: 6.8.0.oce-0.17
With a very simple design it drag and drop works, I made an example
Solid made with a Fuse and a Cut
A separate torus
Drag and drop torus in the Fuse
Forcerecompute with macro
The torus is now part of the Solid
I can imagine that with complex models the recompute can fail
Build type: None
A separate torus
- DeepSOIC
It doesn't even have BooleanFragments! This is new to 0.17. They are completely different beast from regular BOPs in that they are implemented in python.Willem wrote:Version: 0.16.6707 (Git)
Dear Willem,Willem wrote: With a very simple design it drag and drop works, I made an example
A separate torus
Fuse like all Boolean operations does work for me too. The operation I need is "Boolean Fragments" (see Part_BooleanFragments or https://www.freecadweb.org/wiki/Part_BooleanFragments) and here the interface behaves different!!
Thanks nevertheless,
BR,
HoWil
ThxDeepSOIC wrote:I recently saw that drag-and-drop support is accessible to python, so I might have a crack at this.
- microelly2
You have to select 3 objects:HoWil wrote:Hi microelly2,microelly2 wrote:you can use a method in the open scad wb to replace components in a boolean tree
1. the complete target (example cut)
2. the subpart which should be replaced (example cylinder)
3. the new subpart (example sphere)
- bp_413.png (59.88 KiB) Viewed 1283 times
- bp_414.png (39.95 KiB) Viewed 1283 times
