Can not excute complex openscad code.
eexpss
Post by eexpss »
My text_on_cylinder function in openscad format.
Maybe freecad can not deal with the ttf font name. anyone help to test? Just need modify first line and last line in the file.
If can do it, it's a easy way to make text on cylinder surface, horizon or vertical.
The function has 3 parameters.
text_on_cylinder("御风而行",5.5,true);
text_on_cylinder.scad
(1.49 KiB) Downloaded 61 times
Re: Can not excute complex openscad code.
Post by Kunda1 »
What version of OCC are you running ?
Help > About FreeCAD > Copy to clipboard
Willem
Post by Willem »
Freecad has also the possibility to upload a macro called "Circular text"
The wiki page: https://www.freecadweb.org/wiki/Macro_Circular_Text
The download page: https://gist.github.com/mario52a/a25e802498bae6959335
eexpss
Post by eexpss »
OS: Ubuntu 16.04.2 LTS
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.11
OCC version: 6.8.0.oce-0.17
eexpss
Post by eexpss »
Willem wrote:Freecad has also the possibility to upload a macro called "Circular text"
I had read it before. seems complex.
Post by Kunda1 »
eexpss wrote:OS: Ubuntu 16.04.2 LTS
You're using an inferior version of FreeCAD. Current stable is 0.16
If you want the latest OCC goodies you need to use the FreeCAD PPA that some diligent folks of this community recently updated. See https://www.freecadweb.org/wiki/CompileOnUnix#Ubuntu
Note: 0.17 is still experimental and not recommended officially for production (although some use it anyway).
NormandC
Post by NormandC »
It is obvious that you didn't bother reading the "IMPORTANT: Please click here and read this first, before asking for help" topic. :roll:
eexpss
Post by eexpss »
Can you sure the new version can run this code right?
I usually only use the software inside the repo.
I am not like daily version.
Willem
Post by Willem »
My advice is to Install the stable version not the daily.
Type :
sudo add-apt-repository ppa:freecad-maintainers/freecad-stable
sudo apt-get update
This will install this version, since you have the same OS as I have :
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
You can check on this forum and you will see that most people use this version. If you want you can also install the daily version so that you have two versions of Freecad on your computer, but I would not do this because for a beginner this is confusing because there are severe changes/improvements between version 0.16 and 0.17.
DeepSOIC
Post by DeepSOIC »
eexpss wrote:Can you sure the new version can run this code right?
We most likely can't, since most of us don't have that font installed.
OpenSCAD importer did get some changes since 0.15, but I didn't ever use it so I have no idea. But there is some chance. Updating to 0.16 definitely won't hurt anyway ;)
