Loft over multiple sketcher bsplines fails
microelly2
Post by microelly2 »
I want to create a loft over some sketches
it is possible to create a loft between two sketches but not over all of them.
there is no error message.
what is the reason?
loft_error.fcstd
(73.89 KiB) Downloaded 18 times
the geometry check for the fusion of all lofts is okay.
abdullah
Re: Loft over multiple sketcher bsplines fails
Post by abdullah »
I do get an error (appearing in the middle of the 3D viewer):
BRepFill profiles are inconsistent
I fact I can loft everything but the top profile. I have done it with part loft and with partdesign loft:
My modified file:
loft_error.fcstd
(237.12 KiB) Downloaded 11 times
abdullah
Post by abdullah »
The first two sections give weird results when including the top one:
microelly2
thank you, so I have to understand what is different in the first profile.
the profiles are generated from a scan,
I want to have on this way a first view of the scan result, where still no user intervention was done.
thats why I have to modify the splines by script on the first try.
abdullah
Post by abdullah »
microelly2 wrote:thank you, so I have to understand what is different in the first profile.
Welcome!
It would help tons to identify what OCC considers to be an "inconsistent profile" for BRepFill. I did a cursory search without any satisfying result.
The fact that it combines just fine the top two sections, and then when adding the a third one it goes nuts is very frustrating. I was thinking of orientation and seam, but then why is ok for the tool to loft the top two sections and go wild with the third?
microelly2
There is always a workaround for loft and sweep.
I will discretize all curves and build a grid what I can use for a bpline surface or at least for a quad mesh. this is good and fast enough for the first step.
