I'm shocked to find this. Make a cube in Part, increase size to 183mmx103mmx1mm. A couple corners of the rectanglular "cube" will now be cut off, as if automatically chamfered.
Now, make a sketch of a rectangle 183mm x 103mm and then pad it to 1mm. Same thing!
Anyone know what's going on? This seems really odd to me, and would make it difficult to make larger parts.
Something as simple as a cube, broken!?!?!
Re: Something as simple as a cube, broken!?!?!
Please provide your FreeCAD details. And than hit "fit all" in your view, as most likely you are on 0.17 and this is a known viewport Issue of the developer version.
- DeepSOIC
Hi!
As ickby said, this is most likely viewport-related problem. For me, switching to perspective view, then zooming out, then back to orthographic usually helps.
Yep, that was it. Thank you guys! BTW, running 0.16 regular version 64 bit.
BTW, info mostly worthless.analog999 wrote:BTW, running 0.16 regular version 64 bit.
- No revision number provided
- No operating system provided
- No hash
- No libraries
