I tested it after I posted my reply. I opened the file in 0.17-dev, switched to PartDesign then created a Part container. After that I selected all objects, and in the Model tree I drag&dropped them on the Part container. After that I could move the Part container any way I wished (by selecting it from the Model tree), using the Placement utility or Draft Move, and everything inside it followed without distortion.NormandC wrote:I think this is where the Part container from 0.17 would come handy.
"Part" may be a misnomer, because it reacts a lot like an assembly of parts would.
Unfortunately all the dependencies seem to get mangled after the drag&drop. Everything is listed on a single level with no element nested under another. I saved the document and reopened it, thinking it might get fixed by being reloaded, but there was no change. This might be a bug.
In any case, when 0.17 is officially released, it will be a much welcome improvement.
