SVG to sketch?
robofly
SVG to sketch?
Post by robofly »
I'm modeling an RC plane fuselage. I'd like to blend airfoil shape into the fuselage. The airfoil is an SVG image. I already succeeded doing this by subtracting shapes with boolean operation, but I'd like to know if it's possible to transfer vertices from SVG into a sketch, so I could have more control?
Files attached.
What I'm trying to achieve
OS: Linux Mint 18.1 Serena
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
body-middle.fcstd
(11.8 KiB) Downloaded 116 times
Re: SVG to sketch?
In Draft Workbench you have Menu->Draft->Draft to Sketch. However this cannot deal yet with Sketcher's new B-Splines. I have written a macro which approximates the splines with circular arcs: https://forum.freecadweb.org/viewtopic. ... 71#p162571
microelly2
Re: SVG to sketch?
Post by microelly2 »
This creates some outer curves
p=App.ActiveDocument.path10
pts=[v.Point for v in p.Shape.Vertexes]
w=Draft.makeWire(pts)
Draft.makeSketch(w,autoconstraints=True)
bc=Part.BSplineCurve()
bc.interpolate(pts)
pk=App.ActiveDocument.addObject("Part::Spline","path10spline")
pk.Shape=bc.toShape()
The path10spline object you can convert to a sketcher bspline with this script:
https://github.com/microelly2/freecad-n ... hspline.py
It's still not optimized but it is a sketch ;)
NormandC
Re: SVG to sketch?
Post by NormandC »
microelly2 wrote:The path10spline object you can convert to a sketcher bspline with this script
robofly wrote:Version: 0.16.6707 (Git)
robofly
Re: SVG to sketch?
Post by robofly »
Thanks a lot microelly2, I got it working (had to install some python dependencies first)!
I have another question. The script creates a new sketch from SVG, is it possible to copy/paste objects from one sketch to another?
NormandC
Re: SVG to sketch?
Post by NormandC »
robofly wrote:Thanks a lot microelly2, I got it working
How? BSplines are not available in 0.16.6707 which is the version you're using, they're being developed in 0.17 which is nowhere near ready to be released.
That was the point I was trying to make to microelly2 in my previous reply: he should have mentioned it...
robofly wrote:is it possible to copy/paste objects from one sketch to another?
It's not. But you can merge sketches into a single one, then you can delete the geometry you don't want. The Merge sketches utility is in the Part Design or Sketch menu.
robofly
Re: SVG to sketch?
Post by robofly »
NormandC wrote: How? BSplines are not available in 0.16.6707 which is the version you're using, they're being developed in 0.17 which is nowhere near ready to be released.
I'm not exactly sure how :oops: Being a cad n00b I did a lot of clicking and lost track, but I have a sketch generated from SVG.
Take a look at the file, maybe you can figure it out. And thanks for the merging tip.
body-middle.fcstd
(30.66 KiB) Downloaded 109 times
NormandC
Re: SVG to sketch?
Post by NormandC »
Your last sketch does not contain curves, but small straight lines.
Re: SVG to sketch?
The Macro I gave needs 0.17 as well (sorry, I forgot because I developed it some time ago), due to the fact that it uses stuff from the Path Workbench. However it might well work with 0.16 too if you integrate parts of Path Workbench's python code in PathUtils.py.
I'm not going to do it myself, because I guess that the conversion to Sketcher splines will come in the near future. The use of (circular) arcs only is still sensible if it comes to the generation of GCode for mill and lathe driving.
