Can I reuse a sketch on another part, basically i am duplicating sketches in parts the problem being when i adjust something i have to adjust all the parts.
Be nice if i could create master sketches that I can then map into multiple parts so I know my parts will match and line up.
Is there an option for something like this in freecad 0.16 or 0.17 nightly?
Linked sketch copies a posibility ?
Re: Linked sketch copies a posibility ?
Could you give an example (hand drawing?) where you need this? It sounds as if you should rather do something else like using expressions in 0.16 or reference a plane or another object in 0.17. It is not a good idea to fork the tree.
You can in the draft workbench clone the sketch. The clones can be moved and scaled. Unfortunately the clones can not be mapped to a face in the part design workbench but they can be padded and pocketed. Here an example of this workflow.
- hearts.fcstd
- (50.45 KiB) Downloaded 29 times
Image attached, this part is made of 2 sketches, the outline and holes and the inner pocket.
I basically want the exact same part but with the pocket changed to a hexagonal to fit a nut hope that makes sense.
I could copy the part but then if i move the screw holes i need to update the other parts to match, most of the parts i want will be variations on this basic shape.
I will try the draft clone example and see if that lets me achieve what i want.
- Screenshot-20170300123835-649x640.png (30.36 KiB) Viewed 883 times
