Sectioning A Sphere And Extruding Between Sections
3D Modeling user
Postby 3D Modeling user » Mon Mar 20, 2017 6:29 pm
Basically want to make a tablet shape with 1/4 sphere's at all four corners.
Is it better to start with a rectangular box or start with 4 sphere sections and
fill in or extrude between them?
Re: Sectioning A Sphere And Extruding Between Sections
Postby chrisb » Mon Mar 20, 2017 9:20 pm
I would model it in Part Design with polyline. Try the m-key after the first line to toggle between different continuation options.
jmaustpc
Postby jmaustpc » Mon Mar 20, 2017 10:53 pm
3D Modeling user wrote:Basically want to make a tablet shape with 1/4 sphere's at all four corners.
I don't understand what you want. Do you mean a tablet as in medication or a computer?
Perhaps you could model one 1/4 sphere then Draft Array, purhapes Polar, then Part WB Fuse.
3D Modeling user
Postby 3D Modeling user » Mon Mar 20, 2017 11:11 pm
Like a flat tablet.
Rectangular with full radius along edges and those become 1/4 spheres at the corners.
Is it better to start with rectangle and add radiuses or make 1/4 spheres and
fill in between them?
Would have to place 1/4 spheres equally apart at four corners first and
extrude and fill between them.
A rectangular flat box with rounded corners. 1" x 4" x 8".
DeepSOIC
Postby DeepSOIC » Mon Mar 20, 2017 11:56 pm
I guess something like this:
I used Part Box (altered length and width), and then filleted all edges with radius just below thickness of the box.
3D Modeling user
Postby 3D Modeling user » Tue Mar 21, 2017 12:53 am
That's correct .Thank you!
Since we're communicating.
How do I 'flatten' a sphere and extrude between the two halves?
Cut it in half after it's flattened and fill in between halves please?
Flatten a sphere say 1:2 ratio. Half as tall as it is deep or wide.
Postby NormandC » Tue Mar 21, 2017 1:22 am
You have a really odd way of communicating. What you describe is simply not a typical CAD work flow.
You wanted spheres, now you want them "flattened"? Why didn't you say so earlier so the others would not waste time proposing solutions that are obviously not what you wanted? :roll:
3D Modeling user wrote:How do I 'flatten' a sphere and extrude between the two halves?
Have you not read the answers that were given to you?
Postby NormandC » Tue Mar 21, 2017 1:33 am
Here's one method.
tablet_with_ellipsoid_edges_normandc1.fcstd
(27.23 KiB) Downloaded 3 times
