Sectioning A Sphere And Extruding Between Sections
3D Modeling user
Post by 3D Modeling user »
Basically want to make a tablet shape with 1/4 sphere's at all four corners.
Is it better to start with a rectangular box or start with 4 sphere sections and
fill in or extrude between them?
Re: Sectioning A Sphere And Extruding Between Sections
I would model it in Part Design with polyline. Try the m-key after the first line to toggle between different continuation options.
jmaustpc
Post by jmaustpc »
3D Modeling user wrote:Basically want to make a tablet shape with 1/4 sphere's at all four corners.
I don't understand what you want. Do you mean a tablet as in medication or a computer?
Perhaps you could model one 1/4 sphere then Draft Array, purhapes Polar, then Part WB Fuse.
3D Modeling user
Like a flat tablet.
Rectangular with full radius along edges and those become 1/4 spheres at the corners.
Is it better to start with rectangle and add radiuses or make 1/4 spheres and
fill in between them?
Would have to place 1/4 spheres equally apart at four corners first and
extrude and fill between them.
A rectangular flat box with rounded corners. 1" x 4" x 8".
DeepSOIC
Post by DeepSOIC »
I guess something like this:
I used Part Box (altered length and width), and then filleted all edges with radius just below thickness of the box.
3D Modeling user
That's correct .Thank you!
Since we're communicating.
How do I 'flatten' a sphere and extrude between the two halves?
Cut it in half after it's flattened and fill in between halves please?
Flatten a sphere say 1:2 ratio. Half as tall as it is deep or wide.
NormandC
Post by NormandC »
You have a really odd way of communicating. What you describe is simply not a typical CAD work flow.
You wanted spheres, now you want them "flattened"? Why didn't you say so earlier so the others would not waste time proposing solutions that are obviously not what you wanted? :roll:
3D Modeling user wrote:How do I 'flatten' a sphere and extrude between the two halves?
Have you not read the answers that were given to you?
NormandC
Post by NormandC »
Here's one method.
tablet_with_ellipsoid_edges_normandc1.fcstd
(27.23 KiB) Downloaded 30 times
