Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Im sure this is simple, but not for me!! simple vertical round tube say 100 dia 25mm wall 1000mm high with a curved section on top 1000mm Radii through 90 deg.
Found it easy to sweep a solid bar using the 100 o/d , and a shell, but could find no way of doing it with a tube, could not put an i/d to the shell thickness or hollow out the bar. This should be easy am I missing something??
The description is simple and it will get more complicated but for now I need to understand the basics. R
extruding or sweeping
Re: extruding or sweeping
Hello RogerS! Welcome to FreeCAD and the Forum
Either sweep an OD solid and ID solid and do a part cut, Or sweep the OD solid, select both ends of your pipe and use Part > Thickness with a -25mm value. OS: Windows 7
"fight the good fight"
