Hi all,
I'm new to freeCAD, and must say I'm struggling to get the basics right. The end goal for me at this stage is to produce a part that has an extrusion in the middle, and 2 mirrored multi sketch lofts (1 either side of the extrusion). Is this something that is achieveable in FreeCad (the lofts will not be simple sketches and will likely need guide curves - does freeCad support this functionality?)
Here is my FreeCad info
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
I have experience with Solidworks, Creo, Inventor etc. which is possibly why I'm finding it hard to start in freeCAD.
I've been able to draw sketches on different planes (just by defining an offset from the X-Y plane) but cannot view them all at the same time, and they do not appear in the loft tool (only one sketch appears). My model tree shows all 3 sketches.
For now what I want to know is how I show all of my sketch planes and sketches in 3D - I need to be able to see everything together so I know what I'm doing.
Appreciate any help
Cheers
New to FreeCad but not to CAD
Re: New to FreeCad but not to CAD
You can toggle the visibility by selecting the element in the tree and hit the space bar. To prevent users from forking their model by default previous elements are usually hidden.thatguy wrote:For now what I want to know is how I show all of my sketch planes and sketches in 3D - I need to be able to see everything together so I know what I'm doing.
I am not sure what you mean by "guide curves". In 0.16 FreeCAD Draft Workbench contains splines and bezier curves. In the upcoming 0.17 (which can be installed in parallel) splines have just been added to Sketcher as well.
Hi thatguy, and welcome!
https://www.freecadweb.org/wiki/index.p ... Part_Sweep
Without seeing the part I'll say that yes, it's possible in FreeCAD.thatguy wrote:The end goal for me at this stage is to produce a part that has an extrusion in the middle, and 2 mirrored multi sketch lofts (1 either side of the extrusion). Is this something that is achieveable in FreeCad
Yes, see the Part WB > Sweep tool.thatguy wrote:(the lofts will not be simple sketches and will likely need guide curves - does freeCad support this functionality?)
I suspect that the two Sketches that don't appear in the Loft tool have crossing geometry or don't form an enclosed area.thatguy wrote:I've been able to draw sketches on different planes (just by defining an offset from the X-Y plane) but cannot view them all at the same time, and they do not appear in the loft tool (only one sketch appears). My model tree shows all 3 sketches.
Hello thatguy,
See https://www.cati.com/blog/2015/02/how-d ... t-feature/
Unfortunately there is no such functionality (yet) in FreeCAD, and the Sweep tool only supports a single path. You may be able to work around this limitation by adding more loft profiles...
I have experience with a few CAD packages myself, and I've always thought that it helped me come to grips with FreeCAD. But I have to admit that I've had the advantage of learning FreeCAD along its development in the past 7 years. I can tell you that back when I started, there was a lot less tools in the GUI (Sketcher didn't exist, nor did Loft and Sweep in the Part workbench)thatguy wrote:I have experience with Solidworks, Creo, Inventor etc. which is possibly why I'm finding it hard to start in freeCAD.
They don't all appear if you apply a zoom "fit all"?thatguy wrote:I've been able to draw sketches on different planes (just by defining an offset from the X-Y plane) but cannot view them all at the same time
In Solidworks, when creating a Loft you have the option to define multiple guide paths between the lofted profiles vertexes.chrisb wrote:I am not sure what you mean by "guide curves".
Thanks for the explanation.NormandC wrote:In Solidworks, when creating a Loft you have the option to define multiple guide paths between the lofted profiles vertexes.
