Hi all and thanks for reading this,
See attachment - I want to create a smooth transition from the rectangular surface to the cylinder (4 times - thus, for all sides).
How do I get this done?
Thanks in advance
How do I create a surface here?
- 2017-03-25 16_35_56-FreeCAD.png (48.33 KiB) Viewed 720 times
Re: How do I create a surface here?
Hello Eagle,
To others (I see bejant is online): I'm preparing a reply...
... Continued
But you need to rethink how you create this model. Don't try to add these surfaces after the solid is made of a plate and a cylinder: start with the loft to create a solid from the transition between a square and a circle.
Then you can add the bottom plate and the hole.
P.S. Please remember to post your FreeCAD info... That way we can ensure you have the latest available version.
OS: Ubuntu 16.04.2 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Part Loft is the tool for that.Eagle wrote:I want to create a smooth transition from the rectangular surface to the cylinder (4 times - thus, for all sides).
Build type: None
- Square_to_Circle_Loft_normandc1.fcstd
- (23.96 KiB) Downloaded 18 times
Thank you very much.
