Hello there,
I swear that I did a set of fine sketches with a L-shape base ("socle" in french) with sides along each edge, with a central pad with a fall. It was looking good (thanks for NormandC who gave me some tips).
Trying to make it even better, I wanted to add on the base some extra areas to put holes for screws. I did use the trim edge tool, construction lines, circles attached to lines, etc.
The result was really appealing, even if sometime I did experience some application crashes .
After good efforts, I went back to my "edge" sketch and then had the (awfully bad ) surprise to see it upside down, as you can see below :
[img] [/img]
When shown together, the external references seems to cause the problem because they were changed in an earlier part.
[img] [/img]
Is there a way to recover ?
Should I redo the model, is there something that I did wrong and should avoid to get this mess again ?
Thanks for all,
Jean-Philippe
OS: Mac OS X
Version: 0.16.6706 (Git)
Branch: tag: 0.16.6706
Python version: 2.7.11
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
Messy sketch after changing external references ?
- Base v7a.FCStd
- (45.3 KiB) Downloaded 33 times
- Screen Shot 2017-03-25 at 17.54.26.png (100.73 KiB) Viewed 818 times
Re: Messy sketch after changing external references ?
If you change things in an underlying sketch in a way that you create new edges or faces you are most likely to break your model. It is the so called topologica naming problem. You may search the forum for more information, e.g. here: https://forum.freecadweb.org/viewtopic. ... 14#p155014.
