Could you explain this a bit more? I can't seem to interpret it.NormandC wrote:[One of these flaws is failed Boolean operations when one of the solid sits flush to a cylinder seam edge.
I get holes in a solid object after sweeping
Re: I get holes in a solid object after sweeping
- kkremitzki
When you create a cylinder you have two circular faces for the top and bottom, and the central piece is sort of like a folded-up rectangle, glued to itself on a seam. You can see this seam in FreeCAD, and the seam edge is just the line segment that connects the top and bottom circular faces. If you have a solid that sits flush to this edge you can get unexpected Boolean operation failures.71GA wrote:Could you explain this a bit more? I can't seem to interpret it.NormandC wrote:[One of these flaws is failed Boolean operations when one of the solid sits flush to a cylinder seam edge.
Thank you very much. So I guess until this is resolved in OCC I have to avoid using helix for making screws.
No, if you have problems just make sure that the helix doesn't start or end at the seam of the bolt blank.71GA wrote:So I guess until this is resolved in OCC I have to avoid using helix for making screws.
This doesn't work. I tried it like this and I still get empty space after I do a boolean cut...bejant wrote:No, if you have problems just make sure that the helix doesn't start or end at the seam of the bolt blank.
You can see that neither helix and neither swept profile are on the bolt seam...
The file:
- 2017-03-27 -- outer threads -- v4.00.fcstd
- (513.88 KiB) Downloaded 16 times
Apparently, this well-known workaround isn't working with the OCC version your FreeCAD version is compiled with (6.9.1).71GA wrote:This doesn't work. I tried it like this and I still get empty space after I do a boolean cut...
Running Macro ForceRecompute on your model repairs it on the following FreeCAD version:
OS: Ubuntu 16.04.2 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Can you try with the AppImage available here: https://github.com/FreeCAD/FreeCAD/releases/tag/0.16
It is based on the Ubuntu package we provide in our PPA repo, and it's compiled with OCC 6.8.0.
I would also suggest another workaround that I've used in the past: remove the chamfer from the end of the screw (in Sketch); apply the cut between Pocket and Sweep; then create a new Revolution and use in a Part Cut on the bolt to make the chamfer.
EDIT: added file Apply a Cut between "Cut" and "Revolution001", the file exceeded the forum attachment limit if I apply it.
