I'm encountering a very strange problem with freecad,
When i cut between a 2 compounds and 1 of them is an array, the cut only applies on 1 or 2 parts of the array.
On the joint screenshot 3 parts of the array should be cut the same way, but you can see that the last one only shows
a line of cut but is not effectively cut.
I tried converting them to compounds, not converting them also, doesn't change anything :/
(in the fcstd file, the Cut006 is the cut that doesnt work)
Do you have an idea ?
Thanks a lot
Cheers,
Freecad version :
OS: "Arch Linux"
Version: 0.16.Unknown
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.9.1
Cut not entirely working on array
- Screenshot_20170328_204641.png (18.6 KiB) Viewed 1412 times
- topcover.fcstd
- (553.65 KiB) Downloaded 21 times
- DeepSOIC
Re: Cut not entirely working on array
Confirmed.
Version: 0.17.10647 (Git)
Hash: 7901cf7ad28952173ec8e2a55c39e8eb5c441e3c
Python version: 2.7.8
OCC version: 7.0.0
This is quite unusual, as all intersections are well defined, and it's rarely a problem for OCC.
OCC version: 7.0.0
I remember something similar in the Path WB with finding drilling holes. It seemed as if the first object is somehow doubled.
- tanderson69
I did a complete recompute with occt 7.1 and it fixes the problem.
Why the feature 'Compound'. It just creates a nested compound as Cut005 is already a compound. See picture. I see you did the same thing with 'Extrude001' and 'Compound002'. You shouldn't need to wrap a single feature in a compound. Try your cut operations directly on 'Cut005' and 'Extrude001' and see if that behaves.
Thanks for your answers,
In fact, i already tried without any compound and it doesn't change anything (I added the compounds in the first place to try to fix it)
Cheers,
Cheers,
- tanderson69
Sorry. I didn't absorb the whole 'compound' explanation in your original post.kennes wrote:Hi,
Cheers,
After deleting Cut006, Compound and Compound002, then creating a new Part Cut on Cut005 from Extrude001, the Cut succeeds on
OS: Ubuntu 16.04.2 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
It also works with the original file if I do a force recompute (Macro ForceRecompute).
Version: 0.17.10646 (Git)
Build type: None
Branch: (detached from 732bd85)
Hash: 809758b7395f8e591a8a196459bf5a014a864aaf
OCC version: 7.1.0
I find it odd that it doesn't work on OCCT 7.0.0...
6.8.0 --> working
6.9.1 --> not working
7.0.0 --> not working
7.1.0 --> working
Build type: None
I confirm ontanderson69 wrote:I did a complete recompute with occt 7.1 and it fixes the problem.
Build type: None
OCC version: 7.1.0
6.8.0 --> working
7.1.0 --> working
- topcover_working_occ680_normandc1.fcstd
- (500.06 KiB) Downloaded 11 times
That being said, there's a more efficient way to build this model that will almost certainly circumvent the issue you're having: make the Draft Array last, after applying the two cut operations on a single pipe.
IMHO, it is best to avoid applying a Boolean cut to a compound that contains separate solids. Here it is easy to avoid.
- topcover_simplified_normandc1.fcstd
- (482.05 KiB) Downloaded 12 times
Allright, thanks a lot for the hint !
I did like you said, cut and then array.
It works great !
I guess it must be some kind of bug, that seems to be resolved in later version of occ
Thanks all
It works great !
Thanks all
