Testing TechDraw: SVG export failing ?
HoWil
Re: Testing TechDraw
Post by HoWil »
The .svg exported with drawing-wb looks like
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<svg
   xmlns:freecad="http://www.freecadweb.org/wiki/index.php?title=Svg_Namespace"
   xmlns:dc="http://purl.org/dc/elements/1.1/"
   xmlns:cc="http://creativecommons.org/ns#"
   xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
   xmlns:svg="http://www.w3.org/2000/svg"
   xmlns="http://www.w3.org/2000/svg"
   xmlns:xlink="http://www.w3.org/1999/xlink"
   xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
   xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
   width="297mm"
   height="210mm"
   viewBox="0 0 297 210"
   version="1.1"
   id="svg2"
   sodipodi:version="0.32"
   inkscape:version="0.48.5 r10040"
   sodipodi:docname="A4_Landscape.svg"
   inkscape:output_extension="org.inkscape.output.svg.inkscape">
  <!-- Working space 10 10 287 200 -->
  <!-- Title block 147 153 287 200 -->
  <metadata
     id="metadata849">
    <rdf:RDF>
      <cc:Work
EDIT
So it looks like the dimensions of the exported .svg are different... causing the scaling?
wandererfan
Post by wandererfan »
HoWil wrote:Here it is (the file was prior included)
We already know that the original included file has the wrong page size. I wanted the output from the two other versions you tested with. If they put out the wrong page size then there is a build problem somewhere because master branch now produces the correct page size for an A4 template.
HoWil
Post by HoWil »
Current I do have access to the following systems:
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10646 (Git)
Build type: None
Branch: (detached from 732bd85)
Hash: 809758b7395f8e591a8a196459bf5a014a864aaf
Python version: 2.7.12
OCC version: 7.1.0
yields:
<svg width="301.752mm" height="213.36mm"
 xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink"  version="1.2" baseProfile="tiny">
<title>FreeCAD SVG Export</title>
<desc>Drawing page: Page exported from FreeCAD document: Unnamed</desc>
<defs>
<radialGradient gradientUnits="userSpaceOnUse" cx="270.583" cy="33.9" r="19.5714" fx="270.583" fy="33.9" xml:id="gradient1">
    <stop offset="0" stop-color="#ff6d0f" stop-opacity="1" />
    <stop offset="1" stop-color="#ff1000" stop-opacity="1" />
</radialGradient>
<radialGradient gradientUnits="userSpaceOnUse" cx="282.646" cy="29.149" r="19.5714" fx="282.646" fy="29.149" xml:id="gradient2">
    <stop offset="0" stop-color="#71b2f8" stop-opacity="1" />
    <stop offset="1" stop-color="#002795" stop-opacity="1" />
</radialGradient>
</defs>
Version: 0.17.10056 (Git)
Build type: Unknown
Branch: femdev
Hash: aebf667a60194df8a454fb70af72bbc4f0194911
OCC version: 7.0.0
yields
<defs>
</radialGradient>
</radialGradient>
</defs>
in Virtualbox:
OS: Ubuntu 16.04.1 LTS
Version: 0.17.9802 (Git)
Build type: None
Hash: bef81531eeb61b31d23b9603364511b76f1f9633
OCC version: 6.8.0.oce-0.17
<defs>
</radialGradient>
</radialGradient>
</defs>
in Virtualbox (system above updated/upgraded to current version):
Build type: None
OCC version: 7.1.0
yields
<defs>
</radialGradient>
</radialGradient>
Maybe others could test this on Linux as well!!
Steps to reproduce the above:
Start FC
change in Part-wb
draw a cube-solid
in data-view change the length of the solid to 200mm (this step is only needed if you want to see my results for a 200mm long beam)
change to Techdraw
insert new default drawing
insert new view of the Part and insert a dimensions on the 200mm edge
export the drawing as .svg
edit the .svg with a text-editor and copy/past the first lines here.
BR,
HoWil
HoWil
Post by HoWil »
And the two versions from another machine as the above related to this post https://forum.freecadweb.org/viewtopic. ... 30#p167282
Version: 0.17.10305 (Git)
Build type: Unknown
Branch: femdev
Hash: 99ba07bc814a85ccad6b3ed98b341a436720c87d
yields
<defs>
</radialGradient>
</radialGradient>
Version: 0.17.10611 (Git)
Build type: None
Hash: 44a9ecd25f27ec3efe52c9de9c95ef2b3e19dd17
OCC version: 7.1.0
yields
<defs>
</radialGradient>
</radialGradient>
</defs>
wandererfan
The only way I can get a wrong page size is by using a version prior to this:
OS: Ubuntu 12.04.5 LTS
Version: 0.17.9893 (Git)
Build type: debug
Branch: HoWil
Hash: 64d0eb95f306495d678a9f8daba43e159f0b3486
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
OCC version: 7.1.0
(Page size fix installed - 64d0eb95 - 2017-01-30)
Don't know what to tell you at this point. Open to suggestions.
HoWil
Post by HoWil »
no one else using Ubuntu 16.04.2? or at least another linux other than 16.04 and 12.04? Have tested all my systems but all on 16.04 show the same behaviour.
Thanks in advance,
HoWil
r-frank
Re: Testing TechDraw: SVG export failing ?
Post by r-frank »
Splitted for better readability.
Please make seperate posts for seperate topics ...
My GrabCAD FreeCAD-Projects
Chris_G
Post by Chris_G »
Here is what I get :
FC info :
OS: Ubuntu Zesty Zapus (development branch)
Version: 0.17.10661 (Git)
Build type: None
Hash: 3b6020cda8fb91b3de33cf812975f1bd2f29cac1
Python version: 2.7.13
OCC version: 7.1.0
wandererfan
HoWil wrote:no one else using Ubuntu 16.04.2? or at least another linux other than 16.04 and 12.04? Have tested all my systems but all on 16.04 show the same behaviour.
Finally got a machine up and running on 16.04 and I CAN reproduce your results. Try adding this to the TechDraw section of your "user.cfg" and let me know what results you get.
            <FCParamGroup Name="Rez">
              <FCFloat Name="Resolution" Value="10.000000000000"/>
            </FCParamGroup>
It seems to fix the problem here :D , but I don't know why :cry:
wf
HoWil
Post by HoWil »
Chris_G wrote:Hi,
Here is what I get: ...
Thx Chris _G and Thx wandererfan for taking and testing this serious/ly. I do a lot of laser cutting for work and also private and this is absolutely a showstopper. Thx again.
r-frank wrote:Splitted for better readability.
Thx Roland. It was not my intention to overtake the original thread. Good decision. Maybe
"Testing TechDraw: scaled SVG export" is a better title.
I am on my way home and will test the suggested.
BR
Howil
