Hi All
My system information is as follows:
OS: Windows 7
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
I have just installed Cura 2.4 on windows and cura add-on on FreeCAD.
When I'm clicking on the "Run Cura engine slicer tool" button following message is popping up in report view:
Running the Python command 'sliceCuraEngine' failed:
File "C:\Users\SHIVAK SINGH\AppData\Roaming\FreeCAD\Mod\cura_engine\Commands.py", line 63, in Activated
panel = SlicerPanel.SlicerPanel()
File "C:\Users\SHIVAK SINGH\AppData\Roaming\FreeCAD\Mod\cura_engine\SlicerPanel.py", line 49, in __init__
self.form = uic.loadUi(self.homeDir + "/.FreeCAD/Mod/FreeCAD-CuraEngine-Plugin/Slicer.ui")
File "<string>", line 4, in <module>
Cannot open fileSave AutoRecovery file: Needed time: 0ms.
Kindly help.
Regards
Error while selecting: "Run Cura engine slicer tool"
Re: Error while selecting: "Run Cura engine slicer tool"
Does it work if you run FreeCAD as administrator?
Hey Perky
I ran it as an administrator too. Still not working. I'm getting the following output.
Running the Python command 'createMachineDef' failed:
File "C:\Users\SHIVAK SINGH\AppData\Roaming\FreeCAD\Mod\cura_engine\Commands.py", line 51, in Activated
panel = MachineDef.PrintBedTaskPanel()
File "C:\Users\SHIVAK SINGH\AppData\Roaming\FreeCAD\Mod\cura_engine\MachineDef.py", line 246, in __init__
self.form = uic.loadUi(self.homeDir + "/.FreeCAD/Mod/FreeCAD-CuraEngine-Plugin/MachineDef.ui")
Cannot open fileLoading Mesh module... done
Cannot open file
Cannot open file
Hi did you check this
And also the repo used? Yorik's or cblt2l one?
There are some path issue with the original one
https://forum.freecadweb.org/viewtopic. ... 90#p137076
That module has not been developed for such a long time now (almost 3 years) that it's possible that the newer versions of Cura Engine are no longer compatible with it.
I still use it, it's still Working.NormandC wrote:That module has not been developed for such a long time now (almost 3 years) that it's possible that the newer versions of Cura Engine are no longer compatible with it.
Cura Change, but CuraEngine didn't change a lot since 3 years.
Hey Nemesis
I read all the treads you hyperlinked.
Thanks a lot Sir SOLVED
Regards
Regards
