Error while selecting: "Run Cura engine slicer tool"
shivaksingh
Post by shivaksingh »
Hi All
My system information is as follows:
OS: Windows 7
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
I have just installed Cura 2.4 on windows and cura add-on on FreeCAD.
When I'm clicking on the "Run Cura engine slicer tool" button following message is popping up in report view:
Running the Python command 'sliceCuraEngine' failed:
File "C:\Users\SHIVAK SINGH\AppData\Roaming\FreeCAD\Mod\cura_engine\Commands.py", line 63, in Activated
panel = SlicerPanel.SlicerPanel()
File "C:\Users\SHIVAK SINGH\AppData\Roaming\FreeCAD\Mod\cura_engine\SlicerPanel.py", line 49, in __init__
self.form = uic.loadUi(self.homeDir + "/.FreeCAD/Mod/FreeCAD-CuraEngine-Plugin/Slicer.ui")
File "<string>", line 4, in <module>
Cannot open fileSave AutoRecovery file: Needed time: 0ms.
Kindly help.
Regards
perky
Re: Error while selecting: "Run Cura engine slicer tool"
Post by perky »
Does it work if you run FreeCAD as administrator?
shivaksingh
Hey Perky
I ran it as an administrator too. Still not working. I'm getting the following output.
Running the Python command 'createMachineDef' failed:
File "C:\Users\SHIVAK SINGH\AppData\Roaming\FreeCAD\Mod\cura_engine\Commands.py", line 51, in Activated
panel = MachineDef.PrintBedTaskPanel()
File "C:\Users\SHIVAK SINGH\AppData\Roaming\FreeCAD\Mod\cura_engine\MachineDef.py", line 246, in __init__
self.form = uic.loadUi(self.homeDir + "/.FreeCAD/Mod/FreeCAD-CuraEngine-Plugin/MachineDef.ui")
Cannot open fileLoading Mesh module... done
Cannot open file
nemesis
Post by nemesis »
Hi did you check this
And also the repo used? Yorik's or cblt2l one?
There are some path issue with the original one
https://forum.freecadweb.org/viewtopic. ... 90#p137076
NormandC
Post by NormandC »
That module has not been developed for such a long time now (almost 3 years) that it's possible that the newer versions of Cura Engine are no longer compatible with it.
nemesis
Post by nemesis »
NormandC wrote:That module has not been developed for such a long time now (almost 3 years) that it's possible that the newer versions of Cura Engine are no longer compatible with it.
I still use it, it's still Working.
Cura Change, but CuraEngine didn't change a lot since 3 years.
shivaksingh
Hey Nemesis
I read all the treads you hyperlinked.
Thanks a lot Sir SOLVED
Regards
