Offset
Offset
Hello I had a solid object. I downgraded to faces, when wires and edges. I wanted to change this profile and extrude again. However, I can not do anything with edges, such as trim, offset...etc. You can see the attachment. I want to create a radius between two line at the end. Can you suggest how this can be done?
- Capture.PNG (26.22 KiB) Viewed 648 times
Re: Offset
Make a sketch of your profile.
2 solutions :
1st solution draw the sketch from scratch and extrude it
2nd Solution, use the Draft_Upgrade tool to come back to a single wire from your edges. then use Draft_Draft2Sketch tool to convert this wire to sketch, then you can apply the constraints you want and modify your profil.
I don't know if it is possible only with Draft WB, as I am a sketcher guy
2 solutions :
Re: Offset
Please check our my freecad model.
Change the dimensions as needed.
