jmaustpc wrote:
Note that the OCC version used in your FreeCAD version is now very old and is also OCE. Does your Salome use the same version?
Another related tip....also there are different transition types in the sweep properties, they only apply if the path had non tangent joints.
It probably uses quite an old version (it's a build from 2015)
I used to regularly build FreeCAD from source but I'm on Mint Linux 17.3 and becasue of dependancy issues I can't do it any more unless I upgrade to Mint 18 (which I don't have time for at the minute), otherwise I would build the dev version to test it out there.
I used to run something like 6 different oce/OCC version that I compiled with various different options, sometimes OCC bugs were regressions, so newer occ did not always solve some bugs. I am on my mobile phone so I can't test just now.
bejant wrote:@crobar, I think you've made it too complicated. The plan view is a circle so the Sweep Path would be that portion of the ellipse between the inclined tangents of the handrail:
You could make 3 line segments (one line segment from tangent to tangent on the ellipse plane, and another two segments from the endpoints of this segment to the midpoint of that portion of the ellipse between these points on what will be the (arc of) ellipse plane. Use Part WB to make a Face from these 3 edges (tick Planar to True), then use Part WB > Extrude (tick Make Solid to True) and Extrude the plane downwards to create a solid. Change to the Part Design WB, create a Sketch of the top face of this Extrude, and Sketcher an Arc of Ellipse on the Extrude. You can use Link To External Geometry and make the endpoints of the 3 edges lie on the Arc of Ellipse. This will be the curved portion of the Sweep Path.
This is really helpful, thanks, I was planning to start figuring this out once I knew sweep or whatever would actually work
bejant wrote:
You would only need to use one cross-section of the handrail profile. It would probably be easiest to correctly locate it at the end of a straight length of the handrail, then create the Sweep (tick Make Solid and Frenet to True). This should make for a smooth Sweep.
This off the top of my head so I hope that makes sense.
Unfortunately sweep won't work because you cannot control the profile rotation in the sweep, that's why I'm looking at loft instead.
apts=[]
for s in Gui.Selection.getSelection():
print s.Label
w=s.Shape.Wires[0]
pts=w.discretize(50)
apts.append(pts)
bs=Part.BSplineSurface()
bs.interpolate(apts)
Part.show(bs.toShape())
Thanks, I think this method is actually the equivalent of what I did in Salome, or closer to it.
crobar wrote:Unfortunately sweep won't work because you cannot control the profile rotation in the sweep
Maybe haven't done what I've suggested? What happens if you try a Sweep of only one shape along the Path, when Arc Of Ellipse is selected as the Path and Frenet is ticked to True?
See attached, the seep results in a shape unsuitable for a stair handrail because of profile rotation
I think it's not forbidden to use more than one sketch for sweeping. Especially if you need more control of twisting profiles.
I simply not understand your global coord. system. Which faces should stay vertical?
Is this what you expect?
UR_ wrote:I think it's not forbidden to use more than one sketch for sweeping. Especially if you need more control of twisting profiles.
Thanks, but no, so the goal is to produce something like this:
Imagine walking up the stairs with your hand on the handrail surface and you will see what I mean.
UR_ wrote:But caution: Your bending machine has to understand what you are doing
Otherise the whole thing has to be 3D printed
This would be produced using 5 axis CNC wood routing!
