Sorry, English is not my mother tongue, if you do not catch something, please ask.
Weird behaviour in one sketch (several parts body, no links between bodies apart a spreadsheet sharing parameters).
In edit mode it takes all modifications and they are recorded, out of this mode, it looks always the same, mods are not take into account.
After deleting sketch and re-creating one, tried to achieve same operations:
- project a point from another sketch (in the same body),
--> save here, no errors
create construction line
Constraint angle of this line with horizontal axis of sketch
Create a point and symmetrize it to projected point with construction line
Create 2 concentric arcs and two lines
here this error appears (did not try to check between save and this step) and sketch do not looks the same in and out of edit mode.
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10802 (Git)
Build type: None
Hash: 10ce910c03347a90712327a7cc7be2bcdee13afc
Python version: 2.7.12
OCC version: 7.1.0
Note: tried to open the file in 0.15, sketch has the same behaviour.
Any hints ? known problem?
Thanks in advance, I'll try to remove confidential stuff inside the file to share it by MP if relevant.
